Re[mapguide-users] trieving Ajax viewer
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Dec 17 08:39:16 EST 2008
You don't have to remove the buttons.
Right under the field where you select what map to use,
there is a bunch of checkboxes. Remove the check mark in those.
(Above the list of commands).
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> Thanks
> I tried it.But empty toolbar strip was displaying on the top of the
> mapframe.at the left side also i dont want the legend control and properties
> diplayer. i want only that ajax viewer panel which displays the map.
> can u give me the suggestion?
> Thanks and Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Just create a weblayout with nothing visible (the map is obviously
>> always visible).
>> Then you can provide all the stuff you want from Visual Studio (buttons,
>> menus, etc.).
>> The setup is the same as described in the developer guide, but the
>> toolbar, etc, won't be visible,
>> and you will have to create it yourself.
>>>    Hi,
>>> Thanks for u r reply.
>>> But  iam using new visual studio web solution.i want this ajax viewer
>>> only
>>> in my web page
>>> How is it possible?
>>> Thanks and Regards,
>>> Padmini
>>>> You can remove the toolbar and others, in the WebLayout, using Studio or
>>>> Maestro.
>>>>>   Hi,
>>>>> Iam using Mapguide opensource 2.0 (with .net 2.0 +IIS 5.1) by using
>>>>> ajax
>>>>> viewer .
>>>>> Now i want to get only ajax viewer  not all the toolbars,taskpanes all
>>>>> these
>>>>> things.
>>>>> i found that this map pane retrieved from the ajaxmappane.tmpl(from
>>>>> www/viewerfiles) but i didnt get the exact code for retrieving only
>>>>> that
>>>>> ajaxviewer.
>>>>> can u tell me the procedure(code for calling this mappane only) to get
>>>>> only
>>>>> that ajax viewer.
>>>>> Thanks and Regards,
>>>>> Padmini
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081217/3656f0af/attachment.html
