[mapguide-users] External SHP file Refresh?
GordonL gordon.luckett at arrowgeomatics.com
Thu Dec 18 13:16:46 EST 2008
Thanks, that did the trick!
   $OldResourceID = new
MgResourceIdentifier('Library://BASEMAP/1_DATA/SHP.FeatureSource');
    $resourceContent = $resourceSrvc->GetResourceContent($OldResourceID);
    $resourceHeader = $resourceSrvc->GetResourceHeader($OldResourceID);
Now I can access the SHP file as soon as I upload it using the MapGuide API.
Thanks guys!  That is a nice trick.
gordon
Kenneth Skovhede, GEOGRAF A/S wrote:
> I actually ran into the same problem yesterday.
> I have not tried to find the explanation, but it seems that some of the
> data (Enumerate Schemas?) is cached.
> The data prewiew shows correct results, but an updated file
> does not show the correct columns in the layer editor.
> The fix is to just open the FeatureSource and click the "Save" button.
> Programatically this can be done with a GetResource() then SetResource()
> call sequence.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> GordonL skrev:
>> Thanks Dave,
>> that is true, the SHP does appear when refreshing within Studio Preview
>> window, but it is still not available to the code.  I wonder if there is
>> a
>> SESSION based version of a Data Preview "refresh" so that I can see the
>> new
>> shp file in the Alias folder...
>> gordon
>> Dave Wilson-3 wrote:
>>> Open your Data Connection and save it again. You could preview to ensure
>>> it picks up the new files first. This assumes of course you have MG
>>> Studio. Not sure if any of the other tools have the previews.
>>> Dave
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GordonL
>>> Sent: Wednesday, December 17, 2008 2:25 PM
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: [mapguide-users] External SHP file Refresh?
>>> Hi all,
>>> I know that one has to restart the server to see the new External File
>>> Alias, but is this true for additional files added to that folder?
>>> How does one refresh the Data Connection to that folder to see the new
>>> file?
>>> My workflow:
>>> 1. User uploads a SHP/DBF/PRJ file into the Aliased folder on the
>>> server.
>>> 2. Programatically connect to the SHP Data Connection that points to
>>> that
>>> folder.
>>> 3. Loops over the Features, harvesting coordinates for inserts into
>>> Oracle
>>> Spatial (using Bind Variables with PHP).
>>> Everything works if I restart the service, but I really need to upload
>>> the
>>> SHP and then use the Data Connection to use the Feature Reader to get
>>> the
>>> geometries.
>>> (I know I can use the SHPLIB outside of MapGuide...but I really like
>>> MapGuide!).
>>> Can anyone suggest another way?  Do I really have to restart the service
>>> to
>>> see the new SHP files in the folder?  I thought I only had to restart
>>> for
>>> new Aliases, not files within them..
>>> regards,
>>> gordon
>>> View this message in context:
>>> http://www.nabble.com/External-SHP-file-Refresh--tp21061784p21061784.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/External-SHP-file-Refresh--tp21061784p21078141.html
