[mapguide-users] mapguide_tile_seeder.html problems
Dave Wilson
dave.wilson at autodesk.com
Thu Dec 18 19:34:14 EST 2008
I'm not a programmer per say, but I'm technical enough to break things rather well :)
I'm trying to use the mapguide_tile_seeer.html in the context of MapGuide Enterprise 2009.
I copied the script to my www folder (virtual directory root of my MapGuide site).
I edited the reference to OpenLayers to be <script src="http://openlayers.org/api/OpenLayers.js"></script>
I changed my main URL.
I changed my bounds to match my map (note for coordinate systems with bounds that are not lat/lon don't include comma separators in the bounds values).
I changed my temp scales to match those defined in my map.
I changed my map definition to point to my map resource.
I changed the base layer group name.
My map is not in a Lat/Lon coordinate system, but Montana State Plane. My map doesn't load. I'm guessing that the line to center the map fails as it's trying to do a map.setCenter(extent.getCenterLonLat());
What do I need to modify this to for non-LonLat maps?
Or is the problem likely something else. I know my path to my map is valid.
Any help is appreciated.
I would also like to add that maybe some comments in the top of the file to highlight the 7 required steps above might be useful in explaining how to use the file :)
Dave
Dave Wilson
GBU CRT, Calgary
Autodesk Canada Inc
Ph: 403.538.3069
Fax: 403.264.1442
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081218/7eeee080/attachment.html
