[mapguide-users] Zoom To Selection
padmini godavarthi
godavarthi.padmini at gmail.com
Mon Dec 22 23:23:03 EST 2008
Thanks for u r reply.
the code u sent is working fine for both the cases
1) for selection of parcel id
2) Zoom to that parcel id
it working fine for individually. when i integrated this code (i want
selection as well as zoomed to the selected parcel id ) its not working.
iam able to get the x, y coordinates of that parcel id.
can u plz tell me the solution.
My code was
My code is as follows:-
NameValueCollection serverVars = Request.ServerVariables;
String strServerVars = "";
foreach (String str in serverVars.AllKeys)
strServerVars += "<br>" + str;
String platform = serverVars["SERVER_SOFTWARE"];
String queryStr = serverVars["QUERY_STRING"];
string queryStr1 = serverVars["Form"];
NameValueCollection requestParams = Request.HttpMethod == "POST" ?
Request.Form : Request.QueryString;
String sessionId = Request.QueryString["SESSION"];
//String sessionId = Request.QueryString["SESSION"]; ;
string realPath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
String configPath = realPath + "webconfig.ini";
MapGuideApi.MgInitializeWebTier(configPath);
MgUserInformation userInfo = new MgUserInformation(sessionId);
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
MgResourceService resService =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
MgFeatureService featureService =
(MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
MgMap map = new MgMap();
map.Open(resService, "oramap");
MgResourceIdentifier fetresource = new
MgResourceIdentifier("Library://Orasample/resora.FeatureSource");
MgFeatureQueryOptions nameQuery = new MgFeatureQueryOptions();
nameQuery.AddFeatureProperty("PARCEL_ID");
nameQuery.SetFilter("PARCEL_ID='670_115'");
MgLayer layer = map.GetLayers().GetItem(@"GEOM_TABLE") as MgLayer;
MgFeatureReader featureReader =
featureService.SelectFeatures(fetresource, layer.GetFeatureClassName(),
nameQuery);
MgSelection selection = new MgSelection(map);
featureReader.ReadNext();
MgByteReader Geom = featureReader.GetGeometry("Geometry");
MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
// featureReader.ReadNext();
MgGeometry featureGeometry = agfReaderWriter.Read(Geom);
selection.AddFeatures(layer, featureReader, 0);
String selectXML = selection.ToXml();
selection.Save(resService, "oramap");
MgPoint centroid = featureGeometry.GetCentroid();
double mapCenterX = centroid.GetCoordinate().GetX();
double mapCenterY = centroid.GetCoordinate().GetY();
featureReader.Close();
Page.ClientScript.RegisterStartupScript(Page.GetType(), "test",
"select('" + selectXML + "'," + mapCenterX + "," + mapCenterY + ");", true);
and my javascript code is as follows
function select(val,x,y) {
alert("1st");
var selectionXML = val;
var xval = x;
var yval = y;
parent.parent.SetSelectionXML(selectionXML);
parent.parent.mapFrame.ZoomToView(xval,yval,2000,true);
parent.parent.refresh;
Thanks and Regards,
Padmini
Nandorov wrote:
> Or maybe ucan try this
> nameQuery.SetFilter("YOUR_QUERY"); // PARCEL_ID ='O1'
> MgLayer layer = map.GetLayers().GetItem("YOUR_LAYER");
> featureReader = featureService.SelectFeatures(YOUR_LAYER_RES_ID,
> "YOUR_LAYER", nameQuery);
> String selectionXML = selection.ToXml();
> ' then apply the selection and the zoom
> function onPageLoad() {
> var selectionXML = '<%= selectionXML %>';
> Nandorov wrote:
>> Hi,
>> sorry for response too late but this month is a busy one (:
>> First we have to make sure you are getting the coordinates, print x and y
>> coordinates just to make sure the query is working well. Then apply a
>> zoomToView with the coordinates u get (hardcode this just to prove).
>> Finally, the setSelectionXml might work. I have done those selections
>> with a xml template. if u want i can share it, but it's php code.
>> Regards
>> padmini godavarthi wrote:
>>> Hi,
>>> Thanks for u r help.
>>> I wrote u r code but in my application it is neither selected the
>>> parcel_id on the map nor zoomed to that parcel_id on the map.
>>> ? Request.Form : Request.QueryString;
>>> MgLayer;
>>> nameQuery);
>>> true);
>>> alert("1st");
>>> var xval = x;
>>> var yval = y;
>>> can u plz tell me the solution so that i can rectify it in my code.
>>> Thanks and Regards,
>>> Padmini
>>> Nandorov wrote:
>>>> Hi,
>>>> you can try this, after applying the filter
>>>> featureReader =featureService.SelectFeatures(parcelId,
>>>> YourLayer.GetFeatureClassName(), nameQuery);
>>>> i did it in php, but in .net might be something like this ;p
>>>> MgByteReader Geom = featureReader.GetGeometry('Geometry'); (or the name
>>>> of ur geometry property)
>>>> -- you get the geometry of ur parcel
>>>> -- then get the center of the polygon and its coordinates
>>>> double mapCenterX = centroid.GetCoordinate().GetX(); -- or if basic dim
>>>> mapCenterX as double = ...
>>>> -- redirect to another page and in the load
>>>> function OnPageLoad(x,y){
>>>> parent.parent.mapFrame.ZoomToView(x,y,2000,true);
>>>> parent.parent.mapFrame.Refresh();
>>>> its something like this. hope it helps
>>>> Regards
>>>>> Hi,
>>>>> Thanks for u rreply.
>>>>> it works fine.when i query with parcel_id='1' it was selected on the
>>>>> map and displays the attributes in the property window.But i want to
>>>>> zoom to that parcel id on the map(like zoom to shape)
>>>>> 1)How is it possible?
>>>>> Regards,
>>>>> Padmini.
>>>>> Nandorov wrote:
>>>>>> featureService.SelectFeatures(parcelId, "GEOM_TABLE", nameQuery);
>>>>>> i think you should use layer class name instead of layer name
>>>>>>> Hi,
>>>>>>> Iam using Mapguide Opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>>>> I want to query the parcel_id and zoomed it on the map
>>>>>>> may code is
>>>>>>> "POST" ?
>>>>>>> string realPath =
>>>>>>> //nameQuery.SetFilter(ConfigurationManager.AppSettings["FieldToFilter"]
>>>>>>> "=" + Globals.gURLParam);
>>>>>>> nameQuery.SetFilter("PARCEL_ID" + "=" + "670_111");
>>>>>>> MgResourceIdentifier parcelId = new
>>>>>>> //Highlight the query result on the map
>>>>>>> MgLayer layer =
>>>>>>> (MgLayer)map.GetLayers().GetItem("GEOM_TABLE");
>>>>>>> featureReader = featureService.SelectFeatures(parcelId,
>>>>>>> "test",
>>>>>>> "select('" + selectXML + "');", true);
>>>>>>> but i got an error at
>>>>>>> 1)can u plz tell me what do u man by faeture class name?
>>>>>>> from where i will gt it?
>>>>>>> Thanks and Regards,
>>>>>>> Padmini.
View this message in context: http://www.nabble.com/Zoom-To-Selection-tp21070073p21139391.html
