[mapguide-users] Taskpane in Mapguide Maestro
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Dec 22 03:35:12 EST 2008
The easy way is to assign a common page,  ea. redirect_on_startup.aspx, and
then use that page to forward to the desired page.
The other way is to save a modified copy of the WebLayout as a temporary
item.
An untested exaple would be:
ServerConnectionI con; //<-- Assign this
WebLayout wl = con.GetWebLayout("Library://mylayout.WebLayout");
wl.TaskPane.InitialTask = "http://www.example.com/my_special_page.html";
string tempid = ResourceIdentifier("xx", ResourceTypes.WebLayout,
con.SessionID);
con.SaveResourceAs(wl, tempid);
//Redirect to the temp weblayout:
Response.Redirect("/mapguide/mapviewerajax/?WEBLAYOUT=" +
Server.UrlEncode(tempid) + "&SESSION=" + Server.UrlEncode(con.SessionID));
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
>    Hi,
> Iam using Mapguide Opensource 2.0 (wiht .Net 2.0 +IIS 5.1).
> Iam Creating my mapdata using Mapguide Maestro. Now i want to add my custom
> page to the ajax viewer weblayout.
> I gave My Customize Web Page path in
>     initial  task in taskpane
> for exqample i gave the path (../sampleapplication/customize.aspx)
> but i want to gave this path  dynamically (through programmetically) to the
> Weblayout
> 1) Can u plz tell me the way so that it will be very helpful to me.
> Thanks and Regards
> Padmini
