[mapguide-users] create a temporary !Mapdefinition and add a layer
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Dec 23 02:14:45 EST 2008
The previous error you had indicated that the xml was invalid.
This is likely because you are not sending the entire xml document to
the server.
Perhaps someone with better PHP skills can help you out.
Regards, Kenneth Skovhede, GEOGRAF A/S
Arnaud De Groof skrev:
> I have changed the line: "$byteSource = new MgByteSource($updatedXml, strlen($updatedXml));" by "$byteSource = new MgByteSource($updatedXml, mb_strlen($updatedXml));"  without success.
> The xml code coming from the initial MapDefinition was carried out
> thanks to Maestro. I join here the result of the $updatedXml:
> <?xml version="1.0" encoding="utf-8"?>
> <MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="MapDefinition-1.0.0.xsd">
>   <Name>New Map</Name>
>   <CoordinateSystem>PROJCS["WGS 84 / UTM zone 48N",GEOGCS["WGS
> 84",DATUM["WGS_1984",SPHEROID["WGS
> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",105],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","32648"]]</CoordinateSystem>
>   <Extents>
>     <MinX>608404.999984747</MinX>
>     <MaxX>641160.000015253</MaxX>
>     <MinY>1121406.87752137</MinY>
>     <MaxY>1142427.99990895</MaxY>
>   </Extents>
>   <BackgroundColor>ffffffff</BackgroundColor>
>   <Metadata/>
> <MapLayer><Name>YYY</Name><ResourceId>Session:92b640a0-ffff-ffff-8002-001aa0d22567_fr_7F0000010AFC0AFB0AFA//
> YYY.LayerDefinition</ResourceId><Selectable>false</Selectable><ShowInLegend>false</ShowInLegend><LegendLabel/><ExpandInLegend>false</ExpandInLegend><Visible>true</Visible><Group/></MapLayer><MapLayer>
>     <Name>Station</Name>
>     <ResourceId>Library://XXX/Station.LayerDefinition</ResourceId>
> Thanks for your help.
> Regards,
> Arnaud De Groof
> E-MAIL DISCLAIMER*
> The present message may contain confidential and/or legally privileged
> information. If you are not the intended addressee and in case of a
> transmission error, please notify the sender immediately and destroy
> this E-mail. Disclosure, reproduction or distribution of this document
> and its possible attachments is strictly forbidden.
> SPACEBEL denies all liability for incomplete, improper, inaccurate,
> intercepted, (partly) destroyed, lost and/or belated transmission of
> the current information given that unencrypted electronic transmission
> cannot currently be guaranteed to be secure or error free.
> Upon request or in conformity with formal, contractual agreements, an
> originally signed hard copy will be sent to you to confirm the
> information contained in this E-mail.
> SPACEBEL denies all liability where E-mail is used for private use.
> SPACEBEL cannot be held responsible for possible viruses that might
> corrupt this message and/or your computer system.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081223/2beb8069/attachment.html
