[mapguide-users] create a temporary !Mapdefinition and add a layer
Arnaud De Groof
Arnaud.DeGroof at spacebel.be
Wed Dec 24 09:51:51 EST 2008
I have found my error. In fact, I used the command "SetRessource" with a WebLayout in place of a MapDefinition. Now the script seems ok.
How to load the WebLayout with the new MapDefinition (with the new layer) and not the MapDefinition coming from the library (without the new layer)?
New code:
<?php
include "../../mapviewerphp/constants.php";
include "../../mapviewerphp/common.php";
// Initialize
MgInitializeWebTier($webconfigFilePath);
$args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
$sessionId = $args['SESSION'];
$mapName = $args['MAPNAME'];
$layerName1 = 'YYY';
$userInfo = new MgUserInformation($sessionId);
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
$resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
$wl = "Library://XXX/XXX.WebLayout"; // TODO Constant!
// Build a string pointing to the new layer in the Session
$rlLayerResourceId = "Session:$sessionId//$layerName1.LayerDefinition";
// Read the XML of the Library Map Definition
$md ="Library://XXX/$mapName.MapDefinition";
$mdResourceId = new MgResourceIdentifier($md);
$mdReader = $resourceService->GetResourceContent($mdResourceId);
$mdXml = $mdReader->ToString();
$mdDomDoc = DOMDocument::loadXML($mdXml);
// Insert the layer in the MapDefinition
$targetNode = $mdDomDoc->getElementsByTagName("MapLayer")->item(0);
$newNode = $targetNode->parentNode->insertBefore(new DOMElement("MapLayer"), $targetNode);
$newNode->appendChild($mdDomDoc->createElement("Name", $layerName1));
$newNode->appendChild($mdDomDoc->createElement("ResourceId", $rlLayerResourceId));
$newNode->appendChild($mdDomDoc->createElement("Selectable", "false"));
$newNode->appendChild($mdDomDoc->createElement("ShowInLegend", "false"));
$newNode->appendChild($mdDomDoc->createElement("LegendLabel"));
$newNode->appendChild($mdDomDoc->createElement("ExpandInLegend", "false"));
$newNode->appendChild($mdDomDoc->createElement("Visible", "true"));
$newNode->appendChild($mdDomDoc->createElement("Group"));
// Write the XML out to form the Session MapDefinition
$updatedXml = $mdDomDoc->saveXML();
$byteSource = new MgByteSource($updatedXml, strlen($updatedXml));
// Create a new MapDefinition (session repository).
$sessionMapName = $mdResourceId->GetName();
$sessionMapDefinition = "Session:$sessionId//$sessionMapName.MapDefinition";
$sessionResourceId = new MgResourceIdentifier($sessionMapDefinition);
// Write the updated MapDefinition
$resourceService->SetResource($sessionResourceId, $byteSource->GetReader(), null);
// Test the new MapDefinition
$mdtest = "Session:$sessionId///$mapName.MapDefinition";
$mdResourceIdtest = new MgResourceIdentifier($mdtest);
$mdReadertest = $resourceService->GetResourceContent($mdResourceIdtest);
$mdXmltest = $mdReader2->ToString();
$mdDomDoctest = DOMDocument::loadXML($mdXmltest);
// Redirect to the Ajax viewer pointing at the map at the desired coordinates.
$redirectTo = "mapguide/mapviewerajax/?WEBLAYOUT=$sessionWebLayout&SESSION=$sessionId";
$host = $_SERVER["HTTP_HOST"];
$url = "http://$host/$redirectTo";
// Redirect!
header("Location: $url");
exit;
Thanks,
Arnaud De Groof
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: mardi 23 décembre 2008 8:15
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] create a temporary !Mapdefinition and add a layer
The previous error you had indicated that the xml was invalid.
This is likely because you are not sending the entire xml document to the server.
Perhaps someone with better PHP skills can help you out.
Regards, Kenneth Skovhede, GEOGRAF A/S
Arnaud De Groof skrev:
I have changed the line: "$byteSource = new MgByteSource($updatedXml, strlen($updatedXml));" by "$byteSource = new MgByteSource($updatedXml, mb_strlen($updatedXml));" without success.
The xml code coming from the initial MapDefinition was carried out thanks to Maestro. I join here the result of the $updatedXml:
<?xml version="1.0" encoding="utf-8"?>
<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" <http://www.w3.org/2001/XMLSchema-instance> xmlns:xsd="http://www.w3.org/2001/XMLSchema" <http://www.w3.org/2001/XMLSchema> xsi:noNamespaceSchemaLocation="MapDefinition-1.0.0.xsd">
<Name>New Map</Name>
<CoordinateSystem>PROJCS["WGS 84 / UTM zone 48N",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",105],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","32648"]]</CoordinateSystem>
<Extents>
<MinX>608404.999984747</MinX>
<MaxX>641160.000015253</MaxX>
<MinY>1121406.87752137</MinY>
<MaxY>1142427.99990895</MaxY>
</Extents>
<BackgroundColor>ffffffff</BackgroundColor>
<Metadata/>
<MapLayer><Name>YYY</Name><ResourceId>Session:92b640a0-ffff-ffff-8002-001aa0d22567_fr_7F0000010AFC0AFB0AFA// YYY.LayerDefinition</ResourceId><Selectable>false</Selectable><ShowInLegend>false</ShowInLegend><LegendLabel/><ExpandInLegend>false</ExpandInLegend><Visible>true</Visible><Group/></MapLayer><MapLayer>
<Name>Station</Name>
<ResourceId>Library://XXX/Station.LayerDefinition</ResourceId>
Thanks for your help.
Regards,
Arnaud De Groof
___________________________________________________________________________________
E-MAIL DISCLAIMER
The present message may contain confidential and/or legally privileged information.
If you are not the intended addressee and in case of a transmission error,
please notify the sender immediately and destroy this E-mail.
Disclosure, reproduction or distribution of this document and its possible
attachments is strictly forbidden.
SPACEBEL denies all liability for incomplete, improper, inaccurate, intercepted,
(partly) destroyed, lost and/or belated transmission of the current information
given that unencrypted electronic transmission cannot currently be guaranteed
to be secure or error free. Upon request or in conformity with formal, contractual
agreements, an originally signed hard copy will be sent to you to confirm
the information contained in this E-mail.
SPACEBEL denies all liability where E-mail is used for private use.
SPACEBEL cannot be held responsible for possible viruses that might corrupt this
message and/or your computer system.
____________________________________________________________________________________
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081224/97644684/attachment.html
