[mapguide-users] Selection in Fusion
Mark Pendergraft
markp at Meadgilman.com
Tue Dec 23 19:20:38 EST 2008
I'm using MGOS 2.02 and IIS 7 on Vista x64. I'm having problems setting
the selection in fusion.
I step through the code and get this error in fusion.js at
ajaxException:
SetSelection Exception: An unclassified exception occurred.
Exception occurred in method MgSelectionBase_FromXml at line 12308 in
file .\MgApi_wrap.cpp
Everything seems to be in order, i just can't seem to figure out what is
causing it to break.
My selection xml is as follows:
<?xml version="1.0" encoding="UTF-8"?><FeatureSet
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
id="75d6a8aa-0000-1000-8002-0021706d98cf"> <Class id="Default:Jobs">
<ID>AQAAAA==</ID> </Class> </Layer></FeatureSet>
Is anyone else having this problem with setting the selection?
PLEASE HELP!!!!
Thanks.
-Mark Pendergraft
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081223/8b46deef/attachment.html
