[mapguide-users] session problem
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Dec 31 05:10:50 EST 2008
There are a number of cases where you can get a "session expired" message.
Are you certain that the service is running?
Have you tried running the MapGuide server from the commandline with the
"run" switch?
(See
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#DebuggingRastersinMapGuide
for details)
What happens if you completely disables the firewall?
Regards, Kenneth Skovhede, GEOGRAF A/S
D.S.KUMAR skrev:
> hello to the members,
> I have installed mapguide opensource in a xp system and it worked well
> in that local host.
> i have altered the ajaxtiledviewersample.php with my own data and it
> did well and also able to access the sample through another xp system
> on the same lan.
> i tried to install the same in another lan system (xp) with dual ip
> configured. while installation the antivirus software given an warning
> that mapguide listens for incoming connection requests and checked ok.
> when i tried to install the sample application and data it worked well.
> but the problem started when i invoked maestro.
> it showed the login page and on giving ok it has given the error
> session expired error 559.
> and in case of login page it showed connection problem
> Then,
> i uninstalled and reinstalled the same but this time antivirus didn't
> give any warning message.
> as it still doesn't worked i have uninstalled the application in the
> first system and tried reinstalling in the second. but no use ......
> few doubts i have is:
> whether it maintains any cache...
> whether it is maintains any registry entries
> on uninstalling the mapguideopensource2.0 folder is not deleted any
> issue with this
> any help in this will be greatly helpful
> with regards,
> Sasikumar Deena
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081231/dfb848c9/attachment.html
