[mapguide-users] Need help in layerdfefinition
lornen lor_nen at yahoo.com
Wed Dec 31 13:44:40 EST 2008
Hi thanks Jackie..
I've resolved this months ago, but thanks a lot anyway!!!
happy new year :)
--- On Fri, 12/26/08, Jackie Ng-2 (via Nabble) <ml-user+148234-933299064 at n2.nabble.com> wrote:
From: Jackie Ng-2 (via Nabble) <ml-user+148234-933299064 at n2.nabble.com>
Subject: Re: Need help in layerdfefinition
To: "lornen" <lor_nen at yahoo.com>
Date: Friday, December 26, 2008, 9:37 AM
Try capturing that xml output, save it to a temp file, and validate it against the LayerDefinition-1.0.0.xsd schema. Visual Studio (assuming you have it) can easily validate the xml for you.
- Jackie
lornen wrote:
This is my first time using MapGuide Enterprise, and I would appreciate some help.
I am getting a XML Parser exception when I tried to SetResource at the last line of the code.
 CODE:
        private void CreateMarkupLayer()
            string markupName = "redline";
            MgSiteConnection site = getSite();
            MgResourceService resourceService = (MgResourceService)site.CreateService(MgServiceType.ResourceService);
            MgFeatureService featureService = (MgFeatureService) site.CreateService(MgServiceType.FeatureService);
            // Create the Markup Feature Source (SDF)
            MgResourceIdentifier markupID = new MgResourceIdentifier("Library://Markup/" + markupName + ".FeatureSource");
            MgFeatureSchema markupSchema = MarkupSchemaFactory.CreateMarkupSchema();
            MgCreateSdfParams sdfParams = new MgCreateSdfParams("LL84", LL84WKT, markupSchema);
            featureService.CreateFeatureSource(markupID, sdfParams);
            LayerDefinitionFactory factory = new LayerDefinitionFactory();
            // Create a line rule.
            string legendLabel = "";
            string filter = "";
            string color = "FF0000FF";
            string lineRule = factory.CreateLineRule(legendLabel,filter,color);
            // Create a line type style.
            string lineTypeStyle = factory.CreateLineTypeStyle(lineRule);
            // Create a scale range.
            string minScale = "0";
            string maxScale = "1000000000000";
            string lineScaleRange = factory.CreateScaleRange(minScale, maxScale, lineTypeStyle);
            // Create the layer definiton.
            string featureClass = "Library://Markup/" + markupName + ".FeatureSource";
            string featureName = "MarkupSchema:Markup";
            string geometry = "SHPGEOM";
            string layerDefinition = factory.CreateLayerDefinition(featureClass, featureName,geometry,lineScaleRange);
            XmlDocument doc = new XmlDocument();
            doc.LoadXml(layerDefinition);
            System.Text.UTF8Encoding utf = new System.Text.UTF8Encoding();
            byte[] BytelayerDefinition = utf.GetBytes(layerDefinition);
            MgByteSource byteSource = new MgByteSource(BytelayerDefinition, BytelayerDefinition.Length);
            byteSource.SetMimeType(MgMimeType.Xml);
            resourceService.SetResource(markupID, byteSource.GetReader(), null);
The string layerDefinition which i got from factory.CreateLayerDefinition() is as follows:
<LayerDefinition version="1.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="LayerDefinition-1.0.0.xsd">
    <VectorLayerDefinition>
      <ResourceId>Library://Markup/redline.FeatureSource</ResourceId>
      <FeatureName>MarkupSchema:Markup</FeatureName>
      <FeatureNameType>FeatureClass</FeatureNameType>
      <Geometry>SHPGEOM</Geometry>
      <VectorScaleRange>
        <MinScale>0</MinScale>
        <MaxScale>1000000000000</MaxScale>
        <LineTypeStyle>
          <LineRule>
            <LegendLabel></LegendLabel>
            <Filter></Filter>
            <LineSymbolization2D>
              <LineStyle>Solid</LineStyle>
              <Thickness>1</Thickness>
              <Color>FF0000FF</Color>
              <Unit>Points</Unit>
            </LineSymbolization2D>
          </LineRule>
        </LineTypeStyle>
      </VectorScaleRange>
    </VectorLayerDefinition>
  </LayerDefinition>
I'm using asp.net, c# and MapGuide Enterprise 2007
Thanks
This email is a reply to your post @ http://n2.nabble.com/Need-help-in-layerdfefinition-tp1814847p1814848.html
You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/Need-help-in-layerdfefinition-tp1814847p2096880.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081231/4e0feec6/attachment.html
