[mapguide-users] Add Point to Existing Layer
gaku
hamazato at yachiyo-eng.co.jp
Sat Feb 2 20:27:33 EST 2008
Yes, I have created the feature source by using Mapguide Studio.
Jackie Ng wrote:
> Have you actually created the feature source pointed to by
> $featureSourceId ? (ie. Have you called
> $featureService->CreateFeatureSource() ?)
> - Jackie
> gaku wrote:
>> Hi all
>> I'm trying to let the user insert a point feature in PHP along with some
>> attributes. The feature source is an SDF file and the code was
>> translated/modified from the PHP example (draw_line). The user can get
>> the X, Y coordinates from another button (works fine).
>> Everything compiles fine and execute well but no feature is added to the
>> feature source. I tried with a converted SDF feature source (didnt change
>> a thing).
>> Did I miss something ? Did I do something wrong :)
>> Any help would be appreciated
>> here's the code :
>> try
>> MgInitializeWebTier($webconfigFilePath);
>> // Get the session information passed from the viewer.
>> $sessionId = ($_SERVER['REQUEST_METHOD'] ==
>> "POST")?$_POST['SESSION']: $_GET['SESSION'];
>> // Get the user information using the session id,
>> // and set up a connection to the site server.
>> $userInfo = new MgUserInformation($sessionId);
>> $siteConnection = new MgSiteConnection();
>> $siteConnection->Open($userInfo);
>> $resourceService =
>> $siteConnection->CreateService(MgServiceType::ResourceService);
>> $featureService =
>> $siteConnection->CreateService(MgServiceType::FeatureService);
>> $featureSourceId = new
>> MgResourceIdentifier('Library://Sample/Data/020101Markup.FeatureSource');
>> $map = new MgMap();
>> $map->Open($resourceService, $mgMapName);
>> //$geometryFactory = new MgGeometryFactory();
>> $wktReaderWriter = new MgWktReaderWriter();
>> $agfReaderWriter = new MgAgfReaderWriter();
>> $geo = $wktReaderWrite->Read("POINT XY ( $x, $y )");
>> $geoByteReader = new MgByteReader();
>> $geoByteReader = $agfReaderWriter->Write($geo);
>> $idid = 500;
>> $propertyValues = new MgPropertyCollection();
>> $propertyValues->Add(new MgInt32Property("ID", $idid ));
>> $propertyValues->Add(new MgStringProperty(name, 'test'));
>> $propertyValues->Add(new MgGeometryProperty('Geometry',
>> $geoByteReader));
>> $commands = new MgFeatureCommandCollection();
>> $commands->Add(new MgInsertFeatures('020101Markup', $propertyValues));
>> $featureService->UpdateFeatures($featureSourceId, $commands, false);
>> catch (MgException $e)
>> $errorMsg = $e->GetMessage();
>> $errorDetail = $e->GetDetails();
>> -------------------------------end of code -------------
>> --Thanks,
View this message in context: http://www.nabble.com/Add-Point-to-Existing-Layer-tp15136337s16610p15249543.html
