[mapguide-users] Add Point to Existing Layer
Jackie Ng jackie.ng at aecsystems.com.au
Sun Feb 3 07:58:56 EST 2008
Oh I see, I thought you were adding points to a session-based feature source.
In that case, did you create a mapguide session via a username that has
permissions to modify site resources?
- Jackie
gaku wrote:
> Yes, I have created the feature source by using Mapguide Studio.
> Jackie Ng wrote:
>> Have you actually created the feature source pointed to by
>> $featureSourceId ? (ie. Have you called
>> $featureService->CreateFeatureSource() ?)
>> - Jackie
>> gaku wrote:
>>> Hi all
>>> I'm trying to let the user insert a point feature in PHP along with some
>>> attributes. The feature source is an SDF file and the code was
>>> translated/modified from the PHP example (draw_line). The user can get
>>> the X, Y coordinates from another button (works fine).
>>> Everything compiles fine and execute well but no feature is added to the
>>> feature source. I tried with a converted SDF feature source (didnt
>>> change a thing).
>>> Did I miss something ? Did I do something wrong :)
>>> Any help would be appreciated
>>> here's the code :
>>> try
>>> 		MgInitializeWebTier($webconfigFilePath);
>>> 		// Get the session information passed from the viewer.
>>>     	$sessionId = ($_SERVER['REQUEST_METHOD'] ==
>>> "POST")?$_POST['SESSION']: $_GET['SESSION'];
>>>     	// Get the user information using the session id,
>>> 	    // and set up a connection to the site server.
>>> 	    $userInfo = new MgUserInformation($sessionId);
>>> 	    $siteConnection = new MgSiteConnection();
>>> 	    $siteConnection->Open($userInfo);
>>> 		$resourceService =
>>> $siteConnection->CreateService(MgServiceType::ResourceService);
>>> 		$featureService =
>>> $siteConnection->CreateService(MgServiceType::FeatureService);
>>> 		$featureSourceId = new
>>> MgResourceIdentifier('Library://Sample/Data/020101Markup.FeatureSource');
>>> 		$map = new MgMap();
>>> 		$map->Open($resourceService, $mgMapName);
>>> 		//$geometryFactory = new MgGeometryFactory();
>>> 		$wktReaderWriter = new MgWktReaderWriter();
>>> 		$agfReaderWriter = new MgAgfReaderWriter();
>>> 		$geo = $wktReaderWrite->Read("POINT XY ( $x, $y )");
>>> 		$geoByteReader = new MgByteReader();
>>> 		$geoByteReader = $agfReaderWriter->Write($geo);
>>> 		$idid = 500;
>>> 		$propertyValues = new MgPropertyCollection();
>>> 		$propertyValues->Add(new MgInt32Property("ID", $idid ));
>>> 		$propertyValues->Add(new MgStringProperty(name, 'test'));
>>> 		$propertyValues->Add(new MgGeometryProperty('Geometry',
>>> $geoByteReader));
>>> 		$commands = new MgFeatureCommandCollection();
>>> 		$commands->Add(new MgInsertFeatures('020101Markup', $propertyValues));
>>> 		$featureService->UpdateFeatures($featureSourceId, $commands, false);
>>> 	catch (MgException $e)
>>> 		$errorMsg = $e->GetMessage();
>>> 		$errorDetail = $e->GetDetails();
>>> -------------------------------end of code -------------
>>> --Thanks,
View this message in context: http://www.nabble.com/Add-Point-to-Existing-Layer-tp15136337s16610p15253230.html
