[mapguide-users] OGR and PostgreSQL...can't see data in table
Traian Stanev
traian.stanev at autodesk.com
Tue Feb 5 15:07:39 EST 2008
Ok so it can see the features and your ID is called ogc_fid, which is ok.
So you have created a layer in Mapguide and can't see the features?
How about you try to create a map and add this layer to the map -- does it automatically pick up the correct extents for the map?
If not, try setting the extents by hand.
Also, try running the Mapguide server from the command line and see if the OGR provider prints any errors to the console.
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Maciej Skorczewski
> Sent: Tuesday, February 05, 2008 3:02 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] OGR and PostgreSQL...can't see data in
> table
> > You would basically be checking to see if it reports any actual
> feature
> > data or not. If so, then the issue is apparently related to the FDO
> OGR
> > provider (or mapguide). If it reports no features then the issue is
> > in the OGR Postgres driver.
> ok i have this.
> http://img227.imageshack.us/img227/1011/63845772fg2.jpg
> so it is fdo ogr provider?
> i see that MapGuide OS 1.2 is compatible whit fdo FDO 3.2.3
> http://trac.osgeo.org/mapguide/wiki/Release/1.2/Notes
> now i use FDO 3.2.2.66
> i will try to use FDO 3.2.3 and ogr 3.2.3
> http://download.osgeo.org/fdo/3.2.3/
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
