[mapguide-users] OGR and PostgreSQL...can't see data in table
Maciej Skorczewski maciej.skorczewski at procad.pl
Tue Feb 5 16:22:49 EST 2008
> So you have created a layer in Mapguide and can't see the features?
i see this layer in mapguide but can't make join on postgresql table. I
try to add label from postgresql database.
I  have layer (it come from shp file), and it had FeatId field (ex.
value are  1 , 2,  3 ,4 ....1999)
--street_layer---
1.Featid
--database table---(postgresql)
1.ogc_fid
2.Name (this field is change by user whit www interface)
now i try to join it by Featid (shp) to ogc_fid (database) ...i my
aplication user change name of ex. line (street) and then mapguide show
(using join on this database table) label of street name.
I change table field like you said and postgis provider see this data in
database table but can't make join (i can define join
http://img229.imageshack.us/img229/6307/22nl8.jpg
but when i create new layer and add this source (whit join)
mapguide don't show joined field.
and that is strange.
what can i do whit this?
ps. i make join on integer field (source layer vs database)
ps2. i try update fdo/ogr  to 3.2.3 ...now i use fdo 3.2.2.66
what version of fdo/ogr  you have?
maciek
> How about you try to create a map and add this layer to the map -- does it automatically pick up the correct extents for the map?
> If not, try setting the extents by hand.
> Also, try running the Mapguide server from the command line and see if the OGR provider prints any errors to the console.
> Traian
