[mapguide-users] IS the Mapguide 2.0.0 Java API backwards compatible?
Zac Spitzer zac.spitzer at gmail.com
Fri Feb 8 22:19:20 EST 2008
i am getting a org.osgeo.mapguide.MgInvalidStreamHeaderException: Invalid
stream header exception.
at org.osgeo.mapguide.MapGuideJavaApiJNI.MgFeatureService_GetClassDefinition(Native
Method)
at org.osgeo.mapguide.MgFeatureService.GetClassDefinition(
MgFeatureService.java:141)
trying to use the feature service GetClassDefinition(resource_name,
schema_name, class_name);
I get the same error with both SDF and King Oracle 0.7.3.3 ( for fdo 3.3.0,
full client version) feature sources
On Feb 8, 2008 7:36 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> i tried it, i got a few errors with things, but i need to delve into my
> code to see why
> kinda works for far!
> z
> On Feb 8, 2008 7:16 PM, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
> >  I have noticed a change in the API, where some classes are now
> > inherited from MgGuardDisposable.
> > I'm not entirely sure what side effects this may have, but I'm guessing
> > that it will fail to de-serialize classes, giving an error like 'Invalid
> > Stream'.
> > Apart from that, you obviously have to know what methods you can't use
> > with a 1.2 server.
> > Regards, Kenneth, GEOGRAF A/S
> > Zac Spitzer skrev:
> > Can i use the the Mapguide java api v2.0 to talk to a v1.20 server
> > without any issues?
> > I'm going to test it now, but i would like to know if there is any
> > reason not to do this?
> > Zac Spitzer -
> > http://zacster.blogspot.com (My Blog)
> > +61 405 847 168
> > mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080209/52c595df/attachment.html
