[mapguide-users] mapguide under WebApplication root
Jackie Ng
jackie.ng at aecsystems.com.au
Sat Feb 9 03:10:03 EST 2008
IIS6 supports saving web site/virtual directory configurations to xml files
by right-clicking the website/vdir node and choosing (All Tasks -> Save
configuration to a file)
You can then load this configuration into another web site/virtual directory
by right clicking and choosing (New -> Web Site (from file)) or (New ->
Virtual Directory (from file)).
Through this you should be able to effectively "clone" whole web sites
and/or virtual directories. Have you tried this?
- Jackie
Gunter Becker wrote:
> Hi,
> I try to setup the mapguide virtual directory under my WebApplication root
> in IIS 6 on my development server (Windows Server 2003) so that it looks
> like this:
> http://localhost/myWebApplication/mapguide
> On our production server it works fine when I manually add the mapguide
> virtual directory to a new WebSite (http://www.myWebSite.com/mapguide) but
> on the development server I can't login to MapGuide Administration and
> also can't see the map even though the Ajax-Viewer appears.
> So it seems to me that there is a limit in having multiple mapguide
> virtual directorys on one IIS WebSite (Default WebSite).
> My intention is to have the same application configuration on development
> and production server so that I can use relative paths for the start task
> in WebLayout or the element URL in LayerDefinition. I don't want to host
> my application in the www-root of the mapguide installation.
> Any idea if I can do some more settings to achieve this?
> Gunter
View this message in context: http://www.nabble.com/mapguide-under-WebApplication-root-tp15289624s16610p15369526.html
