[mapguide-users] How to embed the map in my own web page?
dorra2007
dorrdor at yahoo.fr
Sat Feb 9 05:54:13 EST 2008
I have tried the same link ("for jsp", in the browser); I have always:
Invalid repository type.
What is the cause of this exception?!!!!
Kenneth, GEOGRAF A/S wrote:
> This works on my machine, with the Sheboygan data installed:
> http://localhost/mapguide/mapviewernet/ajaxviewer.aspx?weblayout=Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout&username=Anonymous&password=
> Since you are using Jsp, it should be:
> http://localhost/mapguide/mapviewerjava/ajaxviewer.jsp?weblayout=Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout&username=Anonymous&password=
> You can paste the url into a browser to test it, before inserting it as
> an embedded map.
> If you are using the bundled Apache server, you should use:
> http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp?weblayout=Library://Samples/Sheboygan/Layouts/SheboyganJsp.WebLayout&username=Anonymous&password=
> Regards, Kenneth, GEOGRAF A/S
> dorra2007 skrev:
>> That is what I have done.
>> And I have always invalid repositorty type.
>>> You can only display WebLayouts with the viewer.
>>> You must also enter the full path to the weblayout:
>>> Library://mylayout.WebLayout
>>> dorra2007 skrev:
>>>> i have an error message: Invalid repository type.
>>>> Whereas the map is displayed in mapguide studio.
>>>> NB: I use postgis as data source.
>>>>> Yes, the mapviewerajax should be configured with the correct default
>>>>> page.
>>>>> If you use the "mapviewerjava", you must add ajaxviewer.jsp page name.
>>>>> The full url becomes:
>>>>> /mapguide/mapviewerjava/ajaxviewer.jsp?weblayout=Library://mylayout.WebLayout&username=Anonymous&password=
>>>>> dorra2007 skrev:
>>>>>> Thank you Kenneth for the code segment;
>>>>>> But there is no folder named mapviewerajax; so I have changed it to
>>>>>> mapviewerjava. I have tried it and the result is the title (This is
>>>>>> my
>>>>>> webpage with an embedded map!)+ blank: the map isnot displayed
>>>>>> (instead
>>>>>> of
>>>>>> the map lays a blank square.)
>>>>>> Have you an idea about what the problem can be?
>>>>>>> Yes, it is possible.
>>>>>>> My favorite method is to embed the Map in an Iframe:
>>>>>>> <html>
>>>>>>> <body>
>>>>>>> <h1>This is my webpage with an embedded map!</h1>
>>>>>>> <iframe
>>>>>>> src="/mapguide/mapviewerajax/?weblayout=Library://mylayout.WebLayout&username=Anonymous&password="
>>>>>>> width="100%" height="100%"></iframe>
>>>>>>> </body>
>>>>>>> </html>
>>>>>>> By adding commands, do you mean from code?
>>>>>>> What sort of commands do you want to add, and why is Studio not an
>>>>>>> option?
>>>>>>> dorra2007 skrev:
>>>>>>>> Hello all;
>>>>>>>> I have one precise question: Is it possible to display the mapguide
>>>>>>>> map
>>>>>>>> in
>>>>>>>> my own web page?
>>>>>>>> If yes; what should I do? And how could I add commands without
>>>>>>>> using
>>>>>>>> mapguide studio?
>>>>>>>> Thank you in advance.
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/How-to-embed-the-map-in-my-own-web-page--tp15130478s16610p15370538.html
