[mapguide-users] Set existing layers visible
Jim O'Leary
jo at pat.ca
Sat Feb 9 23:24:18 EST 2008
I want to programmatically loop through existing layers in my map and set
them visible and display their label in the layers pane according to some
flag. I know this works with new layers that you programmatically make, but
it doesn't work with existing layers. My code is the same as for new layers:
$layer->SetVisible(true);
$layer->SetLegendLabel($layerName);
$layer->SetDisplayInLegend(true);
$layer->ForceRefresh();
$map->Save($resourceService);
In the case of an existing layer, this code sets the layer visible in the
map, but does not display it in the legend. Adding a JavaScript
mapFrame.Refresh()
does not help. In fact, you don't have to do that with an existing layer, it
becomes visible anyway.
After executing this code, I can call
$visible = $layer->GetDisplayInLegend();
$layerName = $layer->GetName();
print "visible for $layerName is $visible<br>";
...and it shows me that the layer is set as visible in the legend. However,
it does not show up in the legend.
Thanks.
Jim O’Leary
Technical
Consultant
Pacific Alliance
Technologies
2nd Floor, 24 East 4th Ave, Vancouver
BC, Canada
V5T1E8
TEL 604.676.6000 TOL 877.691.9171 FAX 604.682.0962
WEB http://www.pat.ca/ www.pat.ca
View this message in context: http://www.nabble.com/Set-existing-layers-visible-tp15393217s16610p15393217.html
