[mapguide-users] Polygon labels - fusion problems
Paul Spencer pagameba at gmail.com
Fri Feb 15 07:32:45 EST 2008
Hi Klemen,
can you make a couple of screenshots that illustrate the problem?
Fusion uses the same MapAgent calls as the ajax viewer to get the map
image, so I can't think of any reason why they would behave
differently in this respect and would like to see the problem in action
Cheers
Paul
On 13-Feb-08, at 5:44 AM, Klemen Sorcnik wrote:
> Hi all,
> I have problem with labeling in fusion .
> Labels positions are in the center of the polygon, and
> are not dynamical move after i pan or resize map, so they
> are not shown  althought polygon is still visible on the screen.
> But if i show the same map in ajax viwer it works just fine.
> Anyone know solution?
> Klemen
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Paul Spencer
CTO, DM Solutions Group Inc
http://www.dmsolutions.ca/
