[mapguide-users] Polygon labels - fusion problems
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Feb 15 08:27:03 EST 2008
Fusion uses OpenLayers to fetch the maps.
OpenLayers load an image that is 1.5 times larger than the current
visible area.
That means that you can pan around a bit, before the map reloads.
This also means that the image is not reloaded from the server before
you pan out of the pre-loaded area.
Could this be the cause of the situation that you describe?
Regards, Kenneth, GEOGRAF A/S
Paul Spencer skrev:
> Hi Klemen,
> can you make a couple of screenshots that illustrate the problem?
> Fusion uses the same MapAgent calls as the ajax viewer to get the map
> image, so I can't think of any reason why they would behave
> differently in this respect and would like to see the problem in action
> Cheers
> Paul
> On 13-Feb-08, at 5:44 AM, Klemen Sorcnik wrote:
>> Hi all,
>> I have problem with labeling in fusion .
>> Labels positions are in the center of the polygon, and
>> are not dynamical move after i pan or resize map, so they
>> are not shown  althought polygon is still visible on the screen.
>> But if i show the same map in ajax viwer it works just fine.
>> Anyone know solution?
>> Klemen
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Paul Spencer
> CTO, DM Solutions Group Inc
> http://www.dmsolutions.ca/
