[mapguide-users] Polygon labels - fusion problems
Traian Stanev traian.stanev at autodesk.com
Fri Feb 15 10:20:23 EST 2008
I think it could be that Fusion uses a RenderMap API which uses viewport clipping turned off (resulting in labels always being at the true centroid of polygons) while the MG ajax viewer uses RenderDynamicOverlay, which has viewport clipping turned on, resulting in polygons being labeled at the centroid of the clipped region.
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Paul Spencer
> Sent: Friday, February 15, 2008 7:33 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Polygon labels - fusion problems
> Hi Klemen,
> can you make a couple of screenshots that illustrate the problem?
> Fusion uses the same MapAgent calls as the ajax viewer to get the map
> image, so I can't think of any reason why they would behave
> differently in this respect and would like to see the problem in action
> Cheers
> Paul
> On 13-Feb-08, at 5:44 AM, Klemen Sorcnik wrote:
> > Hi all,
> > I have problem with labeling in fusion .
> > Labels positions are in the center of the polygon, and
> > are not dynamical move after i pan or resize map, so they
> > are not shown  althought polygon is still visible on the screen.
> > But if i show the same map in ajax viwer it works just fine.
> > Anyone know solution?
> > Klemen
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Paul Spencer
> CTO, DM Solutions Group Inc
> http://www.dmsolutions.ca/
