[mapguide-users] About build in commands
Jackie Ng jackie.ng at aecsystems.com.au
Sat Feb 16 22:44:22 EST 2008
Look at the xml of your weblayout.
Look for your particular command that's inside the <CommandSet> tags. If
that command has a <Target> tag you can change its inner value to
"NewWindow" to have its command launch in a new window.
- Jackie
Rahul sharma wrote:
> Hi
> I am using MapGuide Studio and i have decided to get rid of Task ( right
> panel ) from my final layout . But I am facing problems that some build in
> commands work in that panel . Is there any way i can direct them to
> another window or something .
> Do I  have to write code in order to use that functionality without the
> task pane. \
> If so Can i get some sample code , I am gonna be working withe Buffer ,
> Measure Tool etc
> Thanks
> Rahul
View this message in context: http://www.nabble.com/About-build-in-commands-tp15512788s16610p15525979.html
