[mapguide-users] Get ID from base64 selectionXML
Kenneth, GEOGRAF A/S
ks at geograf.dk
Sun Feb 17 10:15:04 EST 2008
From your notation, I guess that you use PHP.
The ID is Base64 encoded, but it is not a string, it is an integer.
To decode it properly, you must get the bytes (not the string), and
"transform" it into a 32bit integer.
It is encoded in little endian.
If you search the archives, there was a complete explanation earlier,
with PHP code.
Regards, Kenneth, GEOGRAF A/S
Jim O'Leary skrev:
> Is there a way to get the ID of a feature that the user has selected on the
> map directly from the selectionXML rather than create a selection object?
> I have a toolbar invoke URL button with a key=value pair and the value is
> $CurrentSelection. When the user clicks that button, it sends a URL-encoded
> string to my server-side program, which, decoded, looks like this:
> <?xml version="1.0" encoding="UTF-8"?>
> <FeatureSet>
> <Layer id="88faff12-ffff-ffff-8001-005056c00001">
> <Class id="SHP_Schema:Parcels">
> <ID>RiQAAA==</ID>
> </Class>
> </Layer>
> </FeatureSet>
> Using simplexml, I can extract the value of the ID node in two lines:
> $sxe=simplexml_load_string($selectionXML);
> $id = (string)$sxe->Layer->Class->ID;
> If $id (RiQAAA==) is really base64, I should be able to call
> base64_decode($id);
> to get the value of the id, but all I get is F$. What am I missing?
> Thanks.
> Jim O’Leary
> Technical
> Consultant
> Pacific Alliance
> Technologies
> 2nd Floor, 24 East 4th Ave, Vancouver
> BC, Canada
> V5T1E8
> TEL 604.676.6000 TOL 877.691.9171 FAX 604.682.0962
> WEB http://www.pat.ca/ www.pat.ca
