[mapguide-users] Run MGOS 1.2 with IIS 7 (Vista)
mkaram84 mkaram84 at yahoo.com
Mon Feb 18 10:50:22 EST 2008
Thanks for your reply, Brian
Regards
Karam
Berdel, Brian wrote:
> I was installing the asp.net server extensions but you need PHP either
> way in order to run the server admin stuff and Vista / II7 does not
> natively support it, you have to install it and configure yourself.
> Even after doing that, I was still having issues, so I basically gave up
> because it was taking too much time.
> 2.0 would cause the same issues.
> Brian  Berdel
> McMahon Associates, Inc.
> p: 215.283.9444
> www.mcmtrans.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of mkaram84
> Sent: Monday, February 18, 2008 9:31 AM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Run MGOS 1.2 with IIS 7 (Vista)
> Hi Brian
> 1- Did you install PHP or ASP Web Extensions of MapGuide?
> if you installed ASP and the MapGuide run with you, please tell me
> How...
> 2- What about MGOS 2.0, can I run it under the same conditions ?
> thanks for your reply
> (sorry for my english)
> Regards
> Karam
>> I attempted to get it running but it was pretty difficult.  I believe
> it
>> is possible, with a lot of work.   I think Vista SP1 will have better
>> support for PHP so I would wait for that before hosting a site on a
>> Vista machine.
>> Brian  Berdel
>> p: 215.283.9444
>> www.mcmtrans.com
>> Sent: Sunday, February 17, 2008 11:38 AM
>> Subject: [mapguide-users] Run MGOS 1.2 with IIS 7 (Vista)
>> Hi everyone ...
>> Can I run MGOS 1.2 or MGOS 2.0 - in Windows Vista Business with IIS 7
>> If yes, how can i run it?
>> Thanx and Regards
>> Karam
>> View this message in context:
> http://www.nabble.com/Run-MGOS-1.2-with-IIS-7-%28Vista%29-tp15457611s166
>> 10p15457611.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> 10p15546331.html
View this message in context: http://www.nabble.com/Run-MGOS-1.2-with-IIS-7-%28Vista%29-tp15457611s16610p15546898.html
