[mapguide-users] error in building
swetha1 swetha.sub at gmail.com
Tue Feb 19 05:26:04 EST 2008
Hi Vishaal,
I tried inlluding body in the html page still giving the same errors, with a
new error saying "Failed to map the path '/utilityfunctions.aspx' "
The folder contains utilityfunctions.aspx, dont know why it is unable to
find it.
Regards
Swetha
Vishaal wrote:
> Hi Swetha,
> there is nothing to worry about these errors. you can directly run your
> application. these errors come as the frameset is no longer supported by
> html. if you include body in your html page then these eroors will go.
> still you can run your application without any difficulty. try once.
> revert back in case of any problems.
> swetha1 wrote:
>> Hi!
>> I am getting an error when i am trying to build the project.
>> Have attached the screenshot of it, please help me out.
>> Regards
>> Swetha
>>  http://www.nabble.com/file/p15554270/untitled.jpeg
View this message in context: http://www.nabble.com/error-in-building-tp15554270s16610p15559924.html
