[mapguide-users] error in building
Vishaal
vs2k2000 at rediffmail.com
Tue Feb 19 07:13:50 EST 2008
Hi swetha,
my suggestion is just dont blindly copy the samples in your code.
utilityfunctions.aspx is the supported aspx file which u need to include in
your default page by import. also don't forget to add the
utilityfunctions.aspx page to your project.
if you see clearly then you can write the piece of code available in
utilityfunctions.aspx in your default.aspx page to initialize the web tier
and to connect to a map and web layout.
swetha1 wrote:
> Hi Vishaal,
> I tried inlluding body in the html page still giving the same errors, with
> a new error saying "Failed to map the path '/utilityfunctions.aspx' "
> The folder contains utilityfunctions.aspx, dont know why it is unable to
> find it.
> Regards
> Swetha
> Vishaal wrote:
>> Hi Swetha,
>> there is nothing to worry about these errors. you can directly run your
>> application. these errors come as the frameset is no longer supported by
>> html. if you include body in your html page then these eroors will go.
>> still you can run your application without any difficulty. try once.
>> revert back in case of any problems.
>> swetha1 wrote:
>>> Hi!
>>> I am getting an error when i am trying to build the project.
>>> Have attached the screenshot of it, please help me out.
>>> Regards
>>> Swetha
>>> http://www.nabble.com/file/p15554270/untitled.jpeg
View this message in context: http://www.nabble.com/error-in-building-tp15554270s16610p15560573.html
