[mapguide-users] Compound line with Cartographic StylizationEngine
Gunter Becker
Gunter.Becker at csogis.de
Tue Feb 19 11:14:46 EST 2008
Thanks Traian,
RenderingPass was correct. But I had not to sign it to the LayerDefinition but to the SymbolDefinition.
I've created a SymbolDefinition (CompoundSymbolDefinition) in MapGuide Studio where I referenced my previous SolidLine.SymbolDefinition (SimpleSymbolDefinion) and there you can define the RenderingPass-Node. I post it to the end of this message.
But one more note: I use this definition for theming and when working with MapGuide 1.2 this works correct. I tested this also with MapGuide 2.0 RC4 and it fails. The map shows but the theming isn't correct. The line color depend of the extent that is shown (same scale). If I pan through the map the color of the composite / compound line changes several times.
This also happens with default MapGuide theming and stylization. I posted some images to Trac:
#418 - Rendering composite line style for Scale Ranges bug.
Gunter
<CompoundSymbolDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="SymbolDefinition-1.0.0.xsd" version="1.0.0">
<Name>DoubleLine</Name>
<SimpleSymbol>
<SimpleSymbolDefinition>
<Name>BackLine</Name>
<Graphics>
<Path>
<Geometry>M 0.0,0.0 L 1.0,0.0</Geometry>
<LineColor>%LINE_COLOR%</LineColor>
<LineWeight>%LINE_WEIGHT%</LineWeight>
<LineCap>'Round'</LineCap>
<LineJoin>'Round'</LineJoin>
</Path>
</Graphics>
<LineUsage>
<VertexControl>'OverlapWrap'</VertexControl>
<Repeat>1</Repeat>
</LineUsage>
<ParameterDefinition>
<Parameter>
<Identifier>LINE_COLOR</Identifier>
<DefaultValue>ffff0000</DefaultValue>
<DisplayName>Linienfarbe</DisplayName>
<Description>Die Linienfarbe für das Symbol</Description>
<DataType>Color</DataType>
</Parameter>
<Parameter>
<Identifier>LINE_WEIGHT</Identifier>
<DefaultValue>1.0</DefaultValue>
<DisplayName>Linienstärke</DisplayName>
<Description>Die Linienstärke für das Symbol</Description>
<DataType>Real</DataType>
</Parameter>
</ParameterDefinition>
</SimpleSymbolDefinition>
<RenderingPass>0</RenderingPass>
</SimpleSymbol>
<SimpleSymbol>
<SimpleSymbolDefinition> ... like above </SimpleSymbolDefinition>
<RenderingPass>1</RenderingPass>
</SimpleSymbol>
</CompoundSymbolDefinition>
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Traian Stanev
Gesendet: Dienstag, 19. Februar 2008 15:30
An: mapguide-users at lists.osgeo.org
Betreff: RE: [mapguide-users] Compound line with Cartographic StylizationEngine
Try adding setting a RenderingPass tag as follows:
> <SymbolInstance>
> <ResourceId>Library://Symbols/SolidLine.SymbolDefinition</ResourceId>
> <ParameterOverrides>
> <Override>
> <SymbolName>SolidLine</SymbolName>
> <ParameterIdentifier>LINE_COLOR</ParameterIdentifier>
> <ParameterValue>FF8E6D09</ParameterValue>
> </Override>
> <Override>
> <ParameterIdentifier>LINE_WEIGHT</ParameterIdentifier>
> <ParameterValue>3.5</ParameterValue>
> </Override>
> </ParameterOverrides>
> </SymbolInstance>
> <SymbolInstance>
> <Override>
> <ParameterValue>FFFFFA73</ParameterValue>
> </Override>
> <Override>
> <ParameterValue>3.0</ParameterValue>
> </Override>
> </SymbolInstance>
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Gunter Becker
> Sent: Tuesday, February 19, 2008 9:23 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Compound line with Cartographic Stylization
> Engine
> Hi all,
> I would like to have a compound line symbol for street stylization like
> I
> can do with basic stylization in MapGuide Studio. Now I've created a
> SimpleSymbolDefinition called SolidLine and use this two times in the
> CompositeSymbolization of my LayerDefintion. My problem is that the
> line
> features were not melting with each other (see image).
> http://www.nabble.com/file/p15560779/CompoundLine.png
> Has someone done this with success.
> Thanks, Gunter
> The 'SolidLine' SymbolDefinition:
> <Name>SolidLine</Name>
> <Graphics>
> <Path>
> </Path>
> </Graphics>
> <LineUsage>
> <Repeat>1</Repeat>
> </LineUsage>
> <Parameter> ... </Parameter>
> I use it in my LayerDefinition as follows:
> <CompositeSymbolization>
> <SymbolInstance>
> <Override>
> </Override>
> <Override>
> </Override>
> </SymbolInstance>
> <SymbolInstance>
> <Override>
> </Override>
> <Override>
> </Override>
> </SymbolInstance>
> View this message in context: http://www.nabble.com/Compound-line-with-
> Cartographic-Stylization-Engine-tp15560779s16610p15560779.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
