[mapguide-users] tool tip image source
    Jackie Ng
    jackie.ng at aecsystems.com.au
    Tue Feb 19 23:48:52 EST 2008
I assume you mean local drive as in the same drive as the MapGuide Web
Extensions installation?
If that's the case, just make sure the path that contains the images is
exposed as an accessible virtual directory in Apache/IIS.
- Jackie
Kencana wrote:
> Hi All,
> In one of the article (written by Andy Morsell), He provide some
> information on how to embed image inside the tooltip. So far, based on his
> sample code, he retrieve the image from some url. My question is, instead
> of pulling it from other site, are we able to pull the image from the
> local drive it self?
> If yes, then where should I put the images? and how can I enter the image
> source?
> Thank you
> Regards,
> Kencana Kesuma
View this message in context: http://www.nabble.com/tool-tip-image-source-tp15582066s16610p15582391.html
