[mapguide-users] tool tip image source
Kencana
bluesky_dyx at hotmail.com
Wed Feb 20 01:30:09 EST 2008
Hi Jackie,
Assume that i place the image under
MapGuideOpenSource/WebServerExtension/www/image.gif
So how should i provide the image path? can i just give ../image.gif or i
must give the url in http://localhost/image.gif?
Thank you
Regards,
Kencana Kesuma
Jackie Ng wrote:
> I assume you mean local drive as in the same drive as the MapGuide Web
> Extensions installation?
> If that's the case, just make sure the path that contains the images is
> exposed as an accessible virtual directory in Apache/IIS.
> - Jackie
> Kencana wrote:
>> Hi All,
>> In one of the article (written by Andy Morsell), He provide some
>> information on how to embed image inside the tooltip. So far, based on
>> his sample code, he retrieve the image from some url. My question is,
>> instead of pulling it from other site, are we able to pull the image from
>> the local drive it self?
>> If yes, then where should I put the images? and how can I enter the image
>> source?
>> Thank you
>> Regards,
>> Kencana Kesuma
View this message in context: http://www.nabble.com/tool-tip-image-source-tp15582066s16610p15583216.html
