[mapguide-users] tool tip image source
Jackie Ng
jackie.ng at aecsystems.com.au
Wed Feb 20 01:34:43 EST 2008
Under the default configuration. http://<your server name>/mapguide maps to
<Your MapGuide Install Dir>\WebServerExtensions\www
And if i recall, the tooltips are processed from the context of
mapviewer[php/java/net]
So therefore, any of the following urls should work
http://<your server name>/mapguide/image.gif
or
../image.gif
- Jackie
Kencana wrote:
> Hi Jackie,
> Assume that i place the image under
> MapGuideOpenSource/WebServerExtension/www/image.gif
> So how should i provide the image path? can i just give ../image.gif or i
> must give the url in http://localhost/image.gif?
> Thank you
> Regards,
> Kencana Kesuma
> Jackie Ng wrote:
>> I assume you mean local drive as in the same drive as the MapGuide Web
>> Extensions installation?
>> If that's the case, just make sure the path that contains the images is
>> exposed as an accessible virtual directory in Apache/IIS.
>> - Jackie
>> Kencana wrote:
>>> Hi All,
>>> In one of the article (written by Andy Morsell), He provide some
>>> information on how to embed image inside the tooltip. So far, based on
>>> his sample code, he retrieve the image from some url. My question is,
>>> instead of pulling it from other site, are we able to pull the image
>>> from the local drive it self?
>>> If yes, then where should I put the images? and how can I enter the
>>> image source?
>>> Thank you
>>> Regards,
>>> Kencana Kesuma
View this message in context: http://www.nabble.com/tool-tip-image-source-tp15582066s16610p15583255.html
