[mapguide-users] tool tip image source
Kencana
bluesky_dyx at hotmail.com
Wed Feb 20 01:44:48 EST 2008
Hi Jacky,
Thanks for your help :jumping:
Regards,
Kencana
Jackie Ng wrote:
> Under the default configuration. http://<your server name>/mapguide maps
> to <Your MapGuide Install Dir>\WebServerExtensions\www
> And if i recall, the tooltips are processed from the context of
> mapviewer[php/java/net]
> So therefore, any of the following urls should work
> http://<your server name>/mapguide/image.gif
> or
> ../image.gif
> - Jackie
> Kencana wrote:
>> Hi Jackie,
>> Assume that i place the image under
>> MapGuideOpenSource/WebServerExtension/www/image.gif
>> So how should i provide the image path? can i just give ../image.gif or i
>> must give the url in http://localhost/image.gif?
>> Thank you
>> Regards,
>> Kencana Kesuma
>> Jackie Ng wrote:
>>> I assume you mean local drive as in the same drive as the MapGuide Web
>>> Extensions installation?
>>> If that's the case, just make sure the path that contains the images is
>>> exposed as an accessible virtual directory in Apache/IIS.
>>> - Jackie
>>> Kencana wrote:
>>>> Hi All,
>>>> In one of the article (written by Andy Morsell), He provide some
>>>> information on how to embed image inside the tooltip. So far, based on
>>>> his sample code, he retrieve the image from some url. My question is,
>>>> instead of pulling it from other site, are we able to pull the image
>>>> from the local drive it self?
>>>> If yes, then where should I put the images? and how can I enter the
>>>> image source?
>>>> Thank you
>>>> Regards,
>>>> Kencana Kesuma
View this message in context: http://www.nabble.com/tool-tip-image-source-tp15582066s16610p15583338.html
