[mapguide-users] Login error in Autodesk MapGuide Studio 2007
Kenneth, GEOGRAF A/S
ks at geograf.dk
Wed Feb 20 11:44:34 EST 2008
If you have ADN access, you can download Studio 2008.
Do you get the error from the Site Admin as well, or only Studio?
Studio will throw the error you describe for a number of reason (such as
no network, missing files, etc.)
You can try enabling a log of the IIS to see if it actually hits IIS.
Regards, Kenneth, GEOGRAF A/S
Vishaal skrev:
> Hello All,
> today i migrated from MGOS 1.1 to MGOS1.2. i have AutoDesk Map Guide
> Studio2007 ADN copy installed on my mchine. it used to work well with
> MGOS1.1. when i upgraded to MGOS1.2 its giving me login error as user id or
> pwd is incorrect. i havent changed any password. i am using Windows XP Proff
> SP2 and MGOS 1.2 with IIS 6.0 and development in .NET environment.
> kindly have a look at the images. if any one else has encountered same
> problem before then please do let me know the solution.
> thanks in advance.
> Vishal....
> http://www.nabble.com/file/p15587218/AutodeskMapGuideStudioLogin.jpg
> http://www.nabble.com/file/p15587218/AutodeskMapGuideStudioError.jpg
