[mapguide-users] MG 2.0 RC4 selection ALMOST working
Jonathan Manafi jonathan.manafi at cctechnol.com
Thu Feb 21 13:54:37 EST 2008
We realized about the Selection widgets, and we went ahead and included
those in the ApplicationDefinition.xml files that we used. We also noted
that the selection does indeed work with the Sheboygan maps, and as soon
as you select parcels, the map refreshes to indicate your selection, as
well as the SelectionInfo widget shows your selected objects. However,
we used the included Aqua ApplicationDefinition.xml template and only
changed the .MapDefinition files to reflect our maps instead of
Sheboygan and added our custom scripts/urls as widgets to test, and we
are having the selection issues. I even removed everything external to
the initial Aqua template except for one of our maps to load, and the
same thing occurs.
Also of note:
I used the FireBug extension to see the GET and POST commands, and when
running the Sheboygan sample, the selection command issues a POST of
.../fusion/MapGuide/php/Query.php followed by POST
.../fusion/MapGuide/php/Selection.php, whereas our maps only issue POST
of .../fusion/MapGuide/php/Query.php.  I don't know if that has anything
to do with the SelectionInfo showing selected objects for Sheboygan and
not for us, or if all of these issues are just interrelated.
Jonathan
Mike Adair wrote:
> Note that if you are testing with the fusion/samples/mapguide/standard
> example, the SelectionPanel and SelectionInfo widgets aren't enabled
> in the ApplicationDefinition.xml file as shipped.  You have to
> uncomment those widgets in the file.  We should probably change that
> so those widgets are included by default.
> In RC4 with the Sheboygan map, the selection should be appearing
> highlighted as soon as it is selected.
> Mike
> Jason Birch wrote:
>> Oh, looking at your contribution to that thread, it looks like that
>> problem is Fusion-specific, which is different than ary's problem
>> (which is PostGIS-specific).
>> I'm seeing this Fusion selection problem myself on Windows2k3, IIS
>> installation.
>> Jason
>> ________________________________
>> From: mapguide-users-bounces at lists.osgeo.org on behalf of Jason Birch
>> Sent: Thu 2008-02-21 8:32 AM
>> To: MapGuide Users Mail List
>> Subject: RE: [mapguide-users] MG 2.0 RC4 selection ALMOST working
>> Is that just for PostGIS, or is it happening for other feature
>> providers too?
>> Currently Tom has moved that RC4 be tagged as release, so if this is
>> something that is not specific to the PostGIS provider and it is
>> critical, you should make sure to create a ticket in Trac with enough
>> information (data, MGP package, operating system, web server, which
>> viewer you're using) to replicate the problem.
>> If it is PostGIS-specific, then it likely won't be fixed in
>> MapGuide.  Bruno Scott is doing a bunch of work on the PostGIS
>> provider currently, so hopfully it will be fixed through his efforts.
>> Jason
>> From: J Manafi
>> Subject: [mapguide-users] MG 2.0 RC4 selection ALMOST working
>> I was previously having issues with selection
>> (http://www.nabble.com/Postgis-Selection-Problem-%28additional%29-tt15466067s16610.html)
>> where it looked like my objects were selected, but nothing actually
>> was, and RC4 has made great strides to remedy this. However, my
>> current situation is this:
>> I can use the selection tool to make selections on the map. But, they
>> don't show up unless I click the 'Refresh Map' button. And even then,
>> the statusbar still shows No features selected. But when I run our
>> script, the output is correct and formatted accordingly. Yet, If I
>> make a selection programmatically like stated in the linked post, the
>> selection is highlighted, and the statusbar reads {0} features
>> selected on {1} layers, yet shows that two layers are selected in the
>> selection panel, wells and blocks. And, no matter which block I
>> select--even if the block has nothing inside--the selection panel
>> always shows the same two wells selected. Also, if I make a selection
>> with the tool, I cannot use the 'Clear Selection' tool, but it is
>> available when objects are selected programmatically.
>> I don't know what is causing this behavior, but these are my
>> observations so far. If I come across anything new, I will update
>> here. At least the selections are working enough to use and test our
>> scripts, and for that, I am glad.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
