[mapguide-users] MG 2.0 RC4 selection ALMOST working
Mike Adair
madair at dmsolutions.ca
Thu Feb 21 13:58:49 EST 2008
What response are you getting from Query.php for your maps?
Mike
Jonathan Manafi wrote:
> We realized about the Selection widgets, and we went ahead and
> included those in the ApplicationDefinition.xml files that we used. We
> also noted that the selection does indeed work with the Sheboygan
> maps, and as soon as you select parcels, the map refreshes to indicate
> your selection, as well as the SelectionInfo widget shows your
> selected objects. However, we used the included Aqua
> ApplicationDefinition.xml template and only changed the .MapDefinition
> files to reflect our maps instead of Sheboygan and added our custom
> scripts/urls as widgets to test, and we are having the selection
> issues. I even removed everything external to the initial Aqua
> template except for one of our maps to load, and the same thing occurs.
> Also of note:
> I used the FireBug extension to see the GET and POST commands, and
> when running the Sheboygan sample, the selection command issues a POST
> of .../fusion/MapGuide/php/Query.php followed by POST
> .../fusion/MapGuide/php/Selection.php, whereas our maps only issue
> POST of .../fusion/MapGuide/php/Query.php. I don't know if that has
> anything to do with the SelectionInfo showing selected objects for
> Sheboygan and not for us, or if all of these issues are just
> interrelated.
> Jonathan
> Mike Adair wrote:
>> Note that if you are testing with the
>> fusion/samples/mapguide/standard example, the SelectionPanel and
>> SelectionInfo widgets aren't enabled in the ApplicationDefinition.xml
>> file as shipped. You have to uncomment those widgets in the file.
>> We should probably change that so those widgets are included by default.
>> In RC4 with the Sheboygan map, the selection should be appearing
>> highlighted as soon as it is selected.
>> Mike
>> Jason Birch wrote:
>>> Oh, looking at your contribution to that thread, it looks like that
>>> problem is Fusion-specific, which is different than ary's problem
>>> (which is PostGIS-specific).
>>> I'm seeing this Fusion selection problem myself on Windows2k3, IIS
>>> installation.
>>> Jason
>>> ________________________________
>>> From: mapguide-users-bounces at lists.osgeo.org on behalf of Jason Birch
>>> Sent: Thu 2008-02-21 8:32 AM
>>> To: MapGuide Users Mail List
>>> Subject: RE: [mapguide-users] MG 2.0 RC4 selection ALMOST working
>>> Is that just for PostGIS, or is it happening for other feature
>>> providers too?
>>> Currently Tom has moved that RC4 be tagged as release, so if this is
>>> something that is not specific to the PostGIS provider and it is
>>> critical, you should make sure to create a ticket in Trac with
>>> enough information (data, MGP package, operating system, web server,
>>> which viewer you're using) to replicate the problem.
>>> If it is PostGIS-specific, then it likely won't be fixed in
>>> MapGuide. Bruno Scott is doing a bunch of work on the PostGIS
>>> provider currently, so hopfully it will be fixed through his efforts.
>>> Jason
>>> From: J Manafi
>>> Subject: [mapguide-users] MG 2.0 RC4 selection ALMOST working
>>> I was previously having issues with selection
>>> (http://www.nabble.com/Postgis-Selection-Problem-%28additional%29-tt15466067s16610.html)
>>> where it looked like my objects were selected, but nothing actually
>>> was, and RC4 has made great strides to remedy this. However, my
>>> current situation is this:
>>> I can use the selection tool to make selections on the map. But,
>>> they don't show up unless I click the 'Refresh Map' button. And even
>>> then, the statusbar still shows No features selected. But when I run
>>> our script, the output is correct and formatted accordingly. Yet, If
>>> I make a selection programmatically like stated in the linked post,
>>> the selection is highlighted, and the statusbar reads {0} features
>>> selected on {1} layers, yet shows that two layers are selected in
>>> the selection panel, wells and blocks. And, no matter which block I
>>> select--even if the block has nothing inside--the selection panel
>>> always shows the same two wells selected. Also, if I make a
>>> selection with the tool, I cannot use the 'Clear Selection' tool,
>>> but it is available when objects are selected programmatically.
>>> I don't know what is causing this behavior, but these are my
>>> observations so far. If I come across anything new, I will update
>>> here. At least the selections are working enough to use and test our
>>> scripts, and for that, I am glad.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
