[mapguide-users] MG 2.0 RC4 selection ALMOST working
Paul Spencer pagameba at gmail.com
Thu Feb 21 19:34:27 EST 2008
The exception is corrupting the json formatted response so when
Query.php returns there is a (likely suppressed) javascript error that
prevents Fusion from processing the selection and hence other widgets
from responding to it to load the selection.
Mike, we should be able to reproduce this with some of Jason's data.
Cheers
Paul
On 21-Feb-08, at 3:14 PM, Jonathan Manafi wrote:
> This is the response from a query:
> Object not foundERROR: The specified object was not found.
> Exception occurred in method GetItem at line 117 in file d:
> \buildforgeprojects\mapguide_open_source_v2
> .0\build_22.4\mgdev\common\foundation\Data/NamedCollection.cpp
> - GetItem line 117 file d:\buildforgeprojects
> \mapguide_open_source_v2.0\build_22.4\mgdev\common\foundation
> general exceptiongeneral exception{"hasSelection":true,"extents":
> {"minx":-1841749.109647,"miny":10697190
> .314625,"maxx":-1611134.1984211,"maxy":10745845.651758},"layers":
> ["obstructions","platforms","wellbores"
> ,"pipelines","blocks"],"obstructions":{"featureCount":1},"platforms":
> {"featureCount":3},"wellbores":
> {"featureCount":15},"pipelines":{"featureCount":6},"blocks":
> {"featureCount":4}}
> Mike Adair wrote:
>> What response are you getting from Query.php for your maps?
>> Mike
>>> We realized about the Selection widgets, and we went ahead and
>>> included those in the ApplicationDefinition.xml files that we
>>> used. We also noted that the selection does indeed work with the
>>> Sheboygan maps, and as soon as you select parcels, the map
>>> refreshes to indicate your selection, as well as the SelectionInfo
>>> widget shows your selected objects. However, we used the included
>>> Aqua ApplicationDefinition.xml template and only changed
>>> the .MapDefinition files to reflect our maps instead of Sheboygan
>>> and added our custom scripts/urls as widgets to test, and we are
>>> having the selection issues. I even removed everything external to
>>> the initial Aqua template except for one of our maps to load, and
>>> the same thing occurs.
>>> Also of note:
>>> I used the FireBug extension to see the GET and POST commands, and
>>> when running the Sheboygan sample, the selection command issues a
>>> POST of .../fusion/MapGuide/php/Query.php followed by POST .../
>>> fusion/MapGuide/php/Selection.php, whereas our maps only issue
>>> POST of .../fusion/MapGuide/php/Query.php.  I don't know if that
>>> has anything to do with the SelectionInfo showing selected objects
>>> for Sheboygan and not for us, or if all of these issues are just
>>> interrelated.
>>> Jonathan
>>> Mike Adair wrote:
>>>> Note that if you are testing with the fusion/samples/mapguide/
>>>> standard example, the SelectionPanel and SelectionInfo widgets
>>>> aren't enabled in the ApplicationDefinition.xml file as shipped.
>>>> You have to uncomment those widgets in the file.  We should
>>>> probably change that so those widgets are included by default.
>>>> In RC4 with the Sheboygan map, the selection should be appearing
>>>> highlighted as soon as it is selected.
>>>> Mike
>>>> Jason Birch wrote:
>>>>> Oh, looking at your contribution to that thread, it looks like
>>>>> that problem is Fusion-specific, which is different than ary's
>>>>> problem (which is PostGIS-specific).
>>>>> I'm seeing this Fusion selection problem myself on Windows2k3,
>>>>> IIS installation.
>>>>> Jason
>>>>> ________________________________
>>>>> From: mapguide-users-bounces at lists.osgeo.org on behalf of Jason
>>>>> Birch
>>>>> Sent: Thu 2008-02-21 8:32 AM
>>>>> To: MapGuide Users Mail List
>>>>> Subject: RE: [mapguide-users] MG 2.0 RC4 selection ALMOST working
>>>>> Is that just for PostGIS, or is it happening for other feature
>>>>> providers too?
>>>>> Currently Tom has moved that RC4 be tagged as release, so if
>>>>> this is something that is not specific to the PostGIS provider
>>>>> and it is critical, you should make sure to create a ticket in
>>>>> Trac with enough information (data, MGP package, operating
>>>>> system, web server, which viewer you're using) to replicate the
>>>>> problem.
>>>>> If it is PostGIS-specific, then it likely won't be fixed in
>>>>> MapGuide.  Bruno Scott is doing a bunch of work on the PostGIS
>>>>> provider currently, so hopfully it will be fixed through his
>>>>> efforts.
>>>>> Jason
>>>>> From: J Manafi
>>>>> Subject: [mapguide-users] MG 2.0 RC4 selection ALMOST working
>>>>> I was previously having issues with selection (http://www.nabble.com/Postgis-Selection-Problem-%28additional%29-tt15466067s16610.html
>>>>> ) where it looked like my objects were selected, but nothing
>>>>> actually was, and RC4 has made great strides to remedy this.
>>>>> However, my current situation is this:
>>>>> I can use the selection tool to make selections on the map. But,
>>>>> they don't show up unless I click the 'Refresh Map' button. And
>>>>> even then, the statusbar still shows No features selected. But
>>>>> when I run our script, the output is correct and formatted
>>>>> accordingly. Yet, If I make a selection programmatically like
>>>>> stated in the linked post, the selection is highlighted, and the
>>>>> statusbar reads {0} features selected on {1} layers, yet shows
>>>>> that two layers are selected in the selection panel, wells and
>>>>> blocks. And, no matter which block I select--even if the block
>>>>> has nothing inside--the selection panel always shows the same
>>>>> two wells selected. Also, if I make a selection with the tool, I
>>>>> cannot use the 'Clear Selection' tool, but it is available when
>>>>> objects are selected programmatically.
>>>>> I don't know what is causing this behavior, but these are my
>>>>> observations so far. If I come across anything new, I will
>>>>> update here. At least the selections are working enough to use
>>>>> and test our scripts, and for that, I am glad.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Paul Spencer
CTO, DM Solutions Group Inc
http://www.dmsolutions.ca/
