[mapguide-users] map refresh timeout
Traian Stanev
traian.stanev at autodesk.com
Mon Feb 25 13:00:45 EST 2008
Try identifying which layer causes the slow down, by selectively turning off layers. Then see what's peculiar about the layer -- does it have a line style, or perhaps labeling. There is a known issue around that (layers with lots of labels at high zoom), which will be fixed very soon.
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Jonathan Manafi
> Sent: Monday, February 25, 2008 12:54 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] map refresh timeout
> As an update:
> We began testing our data upgrading to MGOS 2.0 RC4 without using the
> fusion library, and we are noticing the same issues. The AGG renderer
> actually causes mgserver.exe to lock up at small zoom scales; today it
> happened at 1:254, whereas the GD renderer has yet to lock up, but it
> still takes a good period of time to update the map extents. Compared
> to
> MGOS 1.2 with the same dataset, both renderers perform worse when
> zoomed
> to a small scale, where, otherwise, they take only split seconds to
> update when zoomed far out.
> Has anyone seen this behavior with their data, as this could be a
> necessary function for our clients?
> J Manafi wrote:
> > I have experienced extremely long refresh rates when the zoom scale
> is really
> > low (~1:33 or so). The time it takes to refresh for the Sheboygan
> example is
> > at least 10x normal, and on a custom map, MapGuide server pretty much
> hangs
> > at ~1:236 (currently sitting and waiting). Has anyone else noticed
> this
> > behavior at low scales?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
