[mapguide-users] map refresh timeout
Zac Spitzer zac.spitzer at gmail.com
Tue Feb 26 20:51:38 EST 2008
Does the server recover from the memory leak or do you need to restart
the server?
On Tue, Feb 26, 2008 at 7:37 AM, Jonathan Manafi
<jonathan.manafi at cctechnol.com> wrote:
> I have narrowed it down to 2 of our layers, where when they are
>  available, the ajax viewer seems to hang at small zooms, or there
>  becomes a horrendous memory leak, where the smaller the scale becomes,
>  the more memory is consumed by mgserver.exe. The most I witnessed turned
>  out to be around 1.2 GB of memory consumed.  With these two layers off,
>  I can zoom down to 1:.001 with no problems. Both of these layers have
>  line styles, and one has a single label at a particular zoom level, but
>  they are both sparse compared to a couple of other layers that have
>  multiple line styles and/or labels.  All of our data being applied is
>  .SDF files.
>  Traian Stanev wrote:
>  > Try identifying which layer causes the slow down, by selectively turning off layers. Then see what's peculiar about the layer -- does it have a line style, or perhaps labeling. There is a known issue around that (layers with lots of labels at high zoom), which will be fixed very soon.
>  > Traian
>  >> -----Original Message-----
>  >> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>  >> bounces at lists.osgeo.org] On Behalf Of Jonathan Manafi
>  >> Sent: Monday, February 25, 2008 12:54 PM
>  >> To: MapGuide Users Mail List
>  >> Subject: Re: [mapguide-users] map refresh timeout
>  >> As an update:
>  >> We began testing our data upgrading to MGOS 2.0 RC4 without using the
>  >> fusion library, and we are noticing the same issues. The AGG renderer
>  >> actually causes mgserver.exe to lock up at small zoom scales; today it
>  >> happened at 1:254, whereas the GD renderer has yet to lock up, but it
>  >> still takes a good period of time to update the map extents. Compared
>  >> to
>  >> MGOS 1.2 with the same dataset, both renderers perform worse when
>  >> zoomed
>  >> to a small scale, where, otherwise, they take only split seconds to
>  >> update when zoomed far out.
>  >> Has anyone seen this behavior with their data, as this could be a
>  >> necessary function for our clients?
>  >> J Manafi wrote:
>  >>> I have experienced extremely long refresh rates when the zoom scale
>  >> is really
>  >>> low (~1:33 or so). The time it takes to refresh for the Sheboygan
>  >> example is
>  >>> at least 10x normal, and on a custom map, MapGuide server pretty much
>  >> hangs
>  >>> at ~1:236 (currently sitting and waiting). Has anyone else noticed
>  >> this
>  >>> behavior at low scales?
>  >> _______________________________________________
>  >> mapguide-users mailing list
>  >> mapguide-users at lists.osgeo.org
>  >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
