[mapguide-users] InitializeWebTier
Jackie Ng jackie.ng at aecsystems.com.au
Thu Feb 28 00:40:52 EST 2008
Did you create a function called InitializeWebTier() ? If you are following
the sample then InitializeWebTier() is defined as follows:
void InitializeWebTier()
      MapGuideApi.MgInitializeWebTier(<path to webconfig.ini>);
- Jackie
swetha1 wrote:
> Hi,
> I am trying to run the dotnetviewersample through visual studio, Which
> gave me lots of errors so i have created a project in which default.aspx
> is created instead of the ajaxviewersample.
> Now if i want to view the map i need to include:
> "Library://UISapp/UIS/Layout/layout.WebLayout"----Which i have prepared in
> MapGuide Studio....
> I am getting an error in the initializeWebTier
> Pasting the code here sp that you guys can understand what i am trying to
> do exactly....
> Please help me out.....
> <%@ Page Language="C#" AutoEventWireup="true"  CodeFile="Default.aspx.cs"
> Inherits="_Default" %>
> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
> "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
> <%@ Import Namespace="System.IO" %>
> <%@ Import Namespace="System.Collections.Specialized" %>
> <%@ Import Namespace="System.Text" %>
> <%@ Import Namespace="System.Globalization" %>
> <%@ Import Namespace="OSGeo.MapGuide" %>
> <%@ Import Namespace="Jayrock.Json" %>
> <%@ Import Namespace="Jayrock.Json.Conversion" %>
> <script runat="server">
> String webLayout = "Library://UISapp/UIS/Layout/layout.WebLayout";
> String defaultUser = "Anonymous";
> String defaultPassword = "";
> String sessionId = "";
> </script>
> try
>         // Initialize a session and register a variable to hold the
>         // session id, then initialize the Web Extensions, connect
>         // to the site, and create a session.
>         InitializeWebTier();
>         MgUserInformation userInfo = new MgUserInformation(defaultUser,
> defaultPassword);
>         MgSite site = new MgSite();
>         site.Open(userInfo);
>         sessionId = site.CreateSession();
>     catch (Exception e)
>         Response.Write(e.Message);
>     <html xmlns="http://www.w3.org/1999/xhtml" >
> <head>
> </head>
> <frameset rows="30,*" frameborder="no" framespacing="0">
> <frame id="titleFrame" frameborder="no" marginwidth="0" marginheight="0"
> scrolling="no" src="title.html">
> <frame id="mapframe" frameborder="no" marginwidth="0" marginheight="0"
> scrolling="no" src= "Library://UISapp/UIS/Layout/layout.WebLayout">
> </frame>
> </frame>
> </frameset>
> </html>
> The error what I am getting when i try debugging is
> Server Error in '/WebSite1' Application.
> Compilation Error
> Description: An error occurred during the compilation of a resource
> required to service this request. Please review the following specific
> error details and modify your source code appropriately.
> Compiler Error Message: CS0103: The name 'InitializeWebTier' does not
> exist in the current context
> Source Error:
> Line 27:         // to the site, and create a session.
> Line 28:
> Line 29:         InitializeWebTier();
> Line 30:
> Line 31:         MgUserInformation userInfo = new
> MgUserInformation(defaultUser, defaultPassword);
> Source File: c:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\WebSite1\Default.aspx
> Line: 29
> Show Detailed Compiler Output:
> c:\Program Files\Microsoft Visual Studio 8\Common7\IDE>
> "C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\csc.exe" /t:library
> /utf8output /R:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary
> ASP.NET
> Files\website1\5fd1ae96\c341d416\assembly\dl3\0986b96d\0096da11_d840c701\JAYROCK.JSON.DLL"
> /R:"C:\WINDOWS\assembly\GAC_32\System.Web\2.0.0.0__b03f5f7f11d50a3a\System.Web.dll"
> /R:"C:\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll"
> /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll"
> /R:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll"
> /R:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET
> Files\website1\5fd1ae96\c341d416\assembly\dl3\ad9baba0\00b23e22_bbaec701\MapGuideDotNetApi.DLL"
> Files\website1\5fd1ae96\c341d416\assembly\dl3\c6d1b217\0096da11_d840c701\JAYROCK.DLL"
> /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Web.Mobile\2.0.0.0__b03f5f7f11d50a3a\System.Web.Mobile.dll"
> /R:"C:\WINDOWS\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll"
> /R:"C:\WINDOWS\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll"
> /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll"
> /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll"
> /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Web.Services\2.0.0.0__b03f5f7f11d50a3a\System.Web.Services.dll"
> /out:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET
> Files\website1\5fd1ae96\c341d416\App_Web_dh8rdadh.dll" /D:DEBUG /debug+
> /optimize-
> /win32res:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET
> Files\website1\5fd1ae96\c341d416\dh8rdadh.res" /w:4 /nowarn:1659;1699;1701
> Files\website1\5fd1ae96\c341d416\App_Web_dh8rdadh.0.cs"
> Files\website1\5fd1ae96\c341d416\App_Web_dh8rdadh.1.cs"
> Files\website1\5fd1ae96\c341d416\App_Web_dh8rdadh.2.cs"
> Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.1433
> for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727
> Copyright (C) Microsoft Corporation 2001-2005. All rights reserved.
> c:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\WebSite1\Default.aspx(29,9):
> error CS0103: The name 'InitializeWebTier' does not exist in the current
> context
> Show Complete Compilation Source:
> Line 1:    #pragma checksum "C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\WebSite1\Default.aspx"
> "{406ea660-64cf-4c82-b6f0-42d48172a799}"
> "CB4B39254C20502CAFF1FFC1695B28F9"
> Line 2:
> Line 3:    // <auto-generated>
> Line 4:    //     This code was generated by a tool.
> Line 5:    //     Runtime Version:2.0.50727.1433
> Line 6:    //
> Line 7:    //     Changes to this file may cause incorrect behavior and
> will be lost if
> Line 8:    //     the code is regenerated.
> Line 9:    // </auto-generated>
> Line 10:
> Line 11:
> Line 12:
> Line 13:
> Line 14:   public partial class _Default :
> System.Web.SessionState.IRequiresSessionState {
> Line 15:
> Line 16:       protected System.Web.Profile.DefaultProfile Profile {
> Line 17:           get {
> Line 18:               return
> ((System.Web.Profile.DefaultProfile)(this.Context.Profile));
> Line 19:           }
> Line 20:       }
> Line 21:
> Line 22:       protected System.Web.HttpApplication ApplicationInstance {
> Line 23:           get {
> Line 24:               return
> ((System.Web.HttpApplication)(this.Context.ApplicationInstance));
> Line 25:           }
> Line 26:       }
> Line 27:   }
> Line 28:   namespace ASP {
> Line 29:
> Line 30:       #line 315
> "C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Config\web.config"
> Line 31:       using System.Web;
> Line 32:
> Line 33:       #line default
> Line 34:       #line hidden
> Line 35:
> Line 36:       #line 10 "C:\Program
> Line 37:       using OSGeo.MapGuide;
> Line 38:
> Line 39:       #line default
> Line 40:       #line hidden
> Line 41:
> Line 42:       #line 316
> Line 43:       using System.Web.Caching;
> Line 44:
> Line 45:       #line default
> Line 46:       #line hidden
> Line 47:
> Line 48:       #line 321
> Line 49:       using System.Web.UI.WebControls;
> Line 50:
> Line 51:       #line default
> Line 52:       #line hidden
> Line 53:
> Line 54:       #line 318
> Line 55:       using System.Web.Security;
> Line 56:
> Line 57:       #line default
> Line 58:       #line hidden
> Line 59:
> Line 60:       #line 8 "C:\Program
> Line 61:       using System.Text;
> Line 62:
> Line 63:       #line default
> Line 64:       #line hidden
> Line 65:
> Line 66:       #line 317
> Line 67:       using System.Web.SessionState;
> Line 68:
> Line 69:       #line default
> Line 70:       #line hidden
> Line 71:
> Line 72:       #line 309
> Line 73:       using System;
> Line 74:
> Line 75:       #line default
> Line 76:       #line hidden
> Line 77:
> Line 78:       #line 7 "C:\Program
> Line 79:       using System.Collections.Specialized;
> Line 80:
> Line 81:       #line default
> Line 82:       #line hidden
> Line 83:
> Line 84:       #line 12 "C:\Program
> Line 85:       using Jayrock.Json.Conversion;
> Line 86:
> Line 87:       #line default
> Line 88:       #line hidden
> Line 89:
> Line 90:       #line 320
> Line 91:       using System.Web.UI;
> Line 92:
> Line 93:       #line default
> Line 94:       #line hidden
> Line 95:
> Line 96:       #line 319
> Line 97:       using System.Web.Profile;
> Line 98:
> Line 99:       #line default
> Line 100:      #line hidden
> Line 101:
> Line 102:      #line 310
> Line 103:      using System.Collections;
> Line 104:
> Line 105:      #line default
> Line 106:      #line hidden
> Line 107:
> Line 108:      #line 314
> Line 109:      using System.Text.RegularExpressions;
> Line 110:
> Line 111:      #line default
> Line 112:      #line hidden
> Line 113:
> Line 114:      #line 11 "C:\Program
> Line 115:      using Jayrock.Json;
> Line 116:
> Line 117:      #line default
> Line 118:      #line hidden
> Line 119:
> Line 120:      #line 9 "C:\Program
> Line 121:      using System.Globalization;
> Line 122:
> Line 123:      #line default
> Line 124:      #line hidden
> Line 125:
> Line 126:      #line 6 "C:\Program
> Line 127:      using System.IO;
> Line 128:
> Line 129:      #line default
> Line 130:      #line hidden
> Line 131:
> Line 132:      #line 322
> Line 133:      using System.Web.UI.WebControls.WebParts;
> Line 134:
> Line 135:      #line default
> Line 136:      #line hidden
> Line 137:
> Line 138:      #line 312
> Line 139:      using System.Configuration;
> Line 140:
> Line 141:      #line default
> Line 142:      #line hidden
> Line 143:
> Line 144:      #line 323
> Line 145:      using System.Web.UI.HtmlControls;
> Line 146:
> Line 147:      #line default
> Line 148:      #line hidden
> Line 149:
> Line 150:
> Line 151:
> [System.Runtime.CompilerServices.CompilerGlobalScopeAttribute()]
> Line 152:      public class default_aspx : global::_Default,
> System.Web.IHttpHandler {
> Line 153:
> Line 154:          private static bool @__initialized;
> Line 155:
> Line 156:          private static object @__stringResource;
> Line 157:
> Line 158:          private static object @__fileDependencies;
> Line 159:
> Line 160:
> Line 161:          #line 14 "C:\Program
> Line 162:
> Line 163:
> Line 164:  String webLayout =
> "Library://Samples/Layouts/DotNetSamples.WebLayout";
> Line 165:  String defaultUser = "Anonymous";
> Line 166:  String defaultPassword = "";
> Line 167:  String sessionId = "";
> Line 168:
> Line 169:
> Line 170:          #line default
> Line 171:          #line hidden
> Line 172:
> Line 173:
> Line 174:          [System.Diagnostics.DebuggerNonUserCodeAttribute()]
> Line 175:          public default_aspx() {
> Line 176:              string[] dependencies;
> Line 177:
> Line 178:              #line 912304 "C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\WebSite1\Default.aspx.cs"
> Line 179:
> ((global::System.Web.UI.Page)(this)).AppRelativeVirtualPath =
> "~/Default.aspx";
> Line 180:
> Line 181:              #line default
> Line 182:              #line hidden
> Line 183:              if ((global::ASP.default_aspx. at __initialized ==
> false)) {
> Line 184:                  global::ASP.default_aspx. at __stringResource =
> this.ReadStringResource();
> Line 185:                  dependencies = new string[2];
> Line 186:                  dependencies[0] = "~/Default.aspx";
> Line 187:                  dependencies[1] = "~/Default.aspx.cs";
> Line 188:                  global::ASP.default_aspx. at __fileDependencies =
> this.GetWrappedFileDependencies(dependencies);
> Line 189:                  global::ASP.default_aspx. at __initialized = true;
> Line 190:              }
> Line 191:              this.Server.ScriptTimeout = 30000000;
> Line 192:          }
> Line 193:
> Line 194:          [System.Diagnostics.DebuggerNonUserCodeAttribute()]
> Line 195:          private void @__BuildControlTree(default_aspx @__ctrl)
> Line 196:
> Line 197:              #line 1 "C:\Program
> Line 198:              this.InitializeCulture();
> Line 199:
> Line 200:              #line default
> Line 201:              #line hidden
> Line 202:              @__ctrl.SetRenderMethodDelegate(new
> System.Web.UI.RenderMethod(this. at __Render__control1));
> Line 203:          }
> Line 204:
> Line 205:          private void
> @__Render__control1(System.Web.UI.HtmlTextWriter @__w,
> System.Web.UI.Control parameterContainer) {
> Line 206:              @__w.Write("\r\n\r\n<!DOCTYPE html PUBLIC
> \"-//W3C//DTD XHTML 1.0 Transitional//EN\" \"http://www.w3" +
> Line 207:
> ".org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\r\n\r\n\r\n");
> Line 208:
> Line 209:              #line 22 "C:\Program
> Line 210:
> Line 211:  try
> Line 212:      {
> Line 213:          // Initialize a session and register a variable to hold
> the
> Line 214:          // session id, then initialize the Web Extensions,
> connect
> Line 215:          // to the site, and create a session.
> Line 216:
> Line 217:          InitializeWebTier();
> Line 218:
> Line 219:          MgUserInformation userInfo = new
> Line 220:          MgSite site = new MgSite();
> Line 221:          site.Open(userInfo);
> Line 222:          sessionId = site.CreateSession();
> Line 223:      }
> Line 224:      catch (Exception e)
> Line 225:      {
> Line 226:          Response.Write(e.Message);
> Line 227:      }
> Line 228:
> Line 229:
> Line 230:              #line default
> Line 231:              #line hidden
> Line 232:              this.WriteUTF8ResourceString(@__w, 0, 428, true);
> Line 233:          }
> Line 234:
> Line 235:
> Line 236:          #line 912304 "C:\Program
> Line 237:          [System.Diagnostics.DebuggerNonUserCodeAttribute()]
> Line 238:          protected override void FrameworkInitialize() {
> Line 239:              base.FrameworkInitialize();
> Line 240:
> this.SetStringResourcePointer(global::ASP.default_aspx. at __stringResource,
> 0);
> Line 241:              this. at __BuildControlTree(this);
> Line 242:
> this.AddWrappedFileDependencies(global::ASP.default_aspx. at __fileDependencies);
> Line 243:              this.Request.ValidateInput();
> Line 244:          }
> Line 245:
> Line 246:          #line default
> Line 247:          #line hidden
> Line 248:
> Line 249:          [System.Diagnostics.DebuggerNonUserCodeAttribute()]
> Line 250:          public override int GetTypeHashCode() {
> Line 251:              return 909526700;
> Line 252:          }
> Line 253:
> Line 254:          [System.Diagnostics.DebuggerNonUserCodeAttribute()]
> Line 255:          public override void
> ProcessRequest(System.Web.HttpContext context) {
> Line 256:              base.ProcessRequest(context);
> Line 257:          }
> Line 258:      }
> Line 259:  }
> Line 260:
View this message in context: http://www.nabble.com/InitializeWebTier-tp15729918s16610p15730087.html
