[mapguide-users] InitializeWebTier
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Feb 28 05:04:02 EST 2008
Odd, there is a leading "/" which indicates that the file
utilityfunctions.aspx file is located at the root of the webserver.
I sill suggest you start over, and don't try to include the ASPX files,
but rather copy paste the code into a codebehind file.
Regards. Kenneth, GEOGRAF A/S
swetha1 skrev:
> have pasted the screen shot of the error
> Swetha
> Kenneth, GEOGRAF A/S wrote:
>> Where does it say "Failed to map utilityfunctions.aspx", is it in the
>> designer, at build time, or at runtime?
>> Are there any references to a line number?
>> If so, what does the line contain, and what about the lines above and
>> below?
>> To get this to work, I would recomend that you create a project, and
>> select IIS as noted previously.
>> Add the MapGuideDotNetApi.dll reference, and copy all files from the
>> mapviewernet/bin folder into the project bin folder.
>> Then create a single new page, select all code functions from the
>> "utilityfunctions.aspx" and paste them into the codebehind file.
>> Repeat the previous step for all required/desired functions/files.
>> This will be a mess, but until you know exactly what functions you need,
>> it is easier to keep them all in the same page.
>> Also, keeping all code in the codebehind file will make debugging and
>> compiling much easier.
>> Regards, Kenneth, GEOGRAF A/S
>> swetha1 skrev:
>>> Well i have copied all the folders available in dotnetviewersample in a
>>> folder created in www...Then opened the same folder in visual
>>> studio....Then as you said have changed the webserver..... Now it is
>>> unable
>>> to find the utilityfunctions.aspx.....It says that failed to map
>>> Regards
>>> Swetha
>>> Jackie Ng wrote:
>>>> You're gonna have to be more specific with the error message.
>>>> - Jackie
>>>> swetha1 wrote:
>>>>> Hi,
>>>>> It is now giving me an error saying "failed to map
>>>>> "utilityfunctions.aspx".....It is in the same folder which is
>>>>> created.....Dont know why it is unable to find it?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/file/p15732169/untitled.jpeg
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080228/9cbe452c/attachment.html
