[mapguide-users] InitializeWebTier
swetha1 swetha.sub at gmail.com
Thu Feb 28 03:54:13 EST 2008
have pasted the screen shot of the error
Swetha
Kenneth, GEOGRAF A/S wrote:
> Where does it say "Failed to map utilityfunctions.aspx", is it in the
> designer, at build time, or at runtime?
> Are there any references to a line number?
> If so, what does the line contain, and what about the lines above and
> below?
> To get this to work, I would recomend that you create a project, and
> select IIS as noted previously.
> Add the MapGuideDotNetApi.dll reference, and copy all files from the
> mapviewernet/bin folder into the project bin folder.
> Then create a single new page, select all code functions from the
> "utilityfunctions.aspx" and paste them into the codebehind file.
> Repeat the previous step for all required/desired functions/files.
> This will be a mess, but until you know exactly what functions you need,
> it is easier to keep them all in the same page.
> Also, keeping all code in the codebehind file will make debugging and
> compiling much easier.
> Regards, Kenneth, GEOGRAF A/S
> swetha1 skrev:
>> Well i have copied all the folders available in dotnetviewersample in a
>> folder created in www....Then opened the same folder in visual
>> studio....Then as you said have changed the webserver..... Now it is
>> unable
>> to find the utilityfunctions.aspx.....It says that failed to map
>> Regards
>> Swetha
>> Jackie Ng wrote:
>>> You're gonna have to be more specific with the error message.
>>> - Jackie
>>> swetha1 wrote:
>>>> Hi,
>>>> It is now giving me an error saying "failed to map
>>>> "utilityfunctions.aspx".....It is in the same folder which is
>>>> created.....Dont know why it is unable to find it?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
http://www.nabble.com/file/p15732169/untitled.jpeg
View this message in context: http://www.nabble.com/InitializeWebTier-tp15729918s16610p15732169.html
