[mapguide-users] Add/Edit on map
Vishaal
vs2k2000 at rediffmail.com
Fri Feb 29 00:42:18 EST 2008
Hi Kenneth,
i was again have a doubt...i want to restrict the information displayed in
the result pane in MGOS. i know that i can do it using the web studio. but
the case is i want to implement user management in the application, and say
if a normal user has logged in the application then he can view only the
specific information whereas the admin can view the each and every
information. this i want to do it on runtime as per the user defined roles.
i hope i made my point clear to you. can you help me out in this.??
Regards,
Vishal
Kenneth, GEOGRAF A/S wrote:
> No, I have not seen this error myself.
> You can use a tool like Process Monitor:
> http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx
> This tool can capture file access, and may give you an explanation.
> I would let the machine run until the error appears.
> Then launch Process Monitor, start capture and run the application.
> You should then be able to see what activity surrounds the
> MapGuideUnmanagedApi.dll, and hopefully guess what goes wrong.
> Its a lot of detective work, and is not guaranteed to give a solution.
> Regards. Kenneth, GEOGRAF A/S
> Vishaal skrev:
>> thanks Kenneth,
>> can you answer my this question also:
>> i am using MGOS1.1 with .NET as development environment.
>> i have made a MapGuide Application and deployed it to a server ( windows
>> server 2003). there is a problem in the application, it works fine for a
>> day
>> or two and after that it gives server error( unable to load
>> MapGuideUnmanagedApi.dll). i have to again deploy the application to make
>> it
>> working.
>> what is the probable cause for this dll getting corrupted? how can i
>> resolve
>> it. i am running into deep trouble because of the malfunctioning of the
>> application.
>> Any help will be appreciated.
>>> Yes, you can add labels runtime, just add a point with an inivisble
>>> signature, and the label appears.
>>> To insert the points at runtime, refer to the post on the mailing list,
>>> that I just made:
>>> "drawing customized markers on the fly"
>>> You can edit the data by accessing the datasource.
>>> If the provider supports updating, you may also edit it.
>>> If you are considering editing objects in the map, you can use a Fusion
>>> layout (which uses OpenLayers),
>>> and then read the WKT from the datasource, and insert it into an
>>> OpenLayers Vector layer.
>>> You can then use OpenLayers to edit the vector layer, and optionally
>>> write data back.
>>> Regards, Kenneth, GEOGRAF A/S
>>> Vishaal skrev:
>>>> Hi Users,
>>>> i want to know that whether it is possible to add labels to a map on
>>>> runtime
>>>> through a text box in MGOS or not??? Also is data editing and addition
>>>> on
>>>> runtime is possible in MGOS(same as ArcGIS Server)??? if yes then
>>>> please
>>>> do
>>>> let me know the road map for how to go about these??
>>>> i am using MGOS 1.2 with Visual Studio2005 on a Windows XP
>>>> Proffessional
>>>> SP2, IIS 6
>>>> thanks in advance.:handshake:
>>>> Vishal
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Add-Edit-on-map-tp15731997s16610p15752503.html
