[mapguide-users] Add/Edit on map
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Feb 28 07:37:35 EST 2008
No, I have not seen this error myself.
You can use a tool like Process Monitor:
http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx
This tool can capture file access, and may give you an explanation.
I would let the machine run until the error appears.
Then launch Process Monitor, start capture and run the application.
You should then be able to see what activity surrounds the
MapGuideUnmanagedApi.dll, and hopefully guess what goes wrong.
Its a lot of detective work, and is not guaranteed to give a solution.
Regards. Kenneth, GEOGRAF A/S
Vishaal skrev:
> thanks Kenneth,
> can you answer my this question also:
> i am using MGOS1.1 with .NET as development environment.
> i have made a MapGuide Application and deployed it to a server ( windows
> server 2003). there is a problem in the application, it works fine for a day
> or two and after that it gives server error( unable to load
> MapGuideUnmanagedApi.dll). i have to again deploy the application to make it
> working.
> what is the probable cause for this dll getting corrupted? how can i resolve
> it. i am running into deep trouble because of the malfunctioning of the
> application.
> Any help will be appreciated.
> Kenneth, GEOGRAF A/S wrote:
>> Yes, you can add labels runtime, just add a point with an inivisble
>> signature, and the label appears.
>> To insert the points at runtime, refer to the post on the mailing list,
>> that I just made:
>> "drawing customized markers on the fly"
>> You can edit the data by accessing the datasource.
>> If the provider supports updating, you may also edit it.
>> If you are considering editing objects in the map, you can use a Fusion
>> layout (which uses OpenLayers),
>> and then read the WKT from the datasource, and insert it into an
>> OpenLayers Vector layer.
>> You can then use OpenLayers to edit the vector layer, and optionally
>> write data back.
>> Regards, Kenneth, GEOGRAF A/S
>> Vishaal skrev:
>>> Hi Users,
>>> i want to know that whether it is possible to add labels to a map on
>>> runtime
>>> through a text box in MGOS or not??? Also is data editing and addition on
>>> runtime is possible in MGOS(same as ArcGIS Server)??? if yes then please
>>> do
>>> let me know the road map for how to go about these??
>>> i am using MGOS 1.2 with Visual Studio2005 on a Windows XP Proffessional
>>> SP2, IIS 6
>>> thanks in advance.:handshake:
>>> Vishal
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080228/f13bbb19/attachment.html
