[mapguide-users] Add/Edit on map
Vishaal
vs2k2000 at rediffmail.com
Thu Feb 28 07:18:41 EST 2008
thanks Kenneth,
can you answer my this question also:
i am using MGOS1.1 with .NET as development environment.
i have made a MapGuide Application and deployed it to a server ( windows
server 2003). there is a problem in the application, it works fine for a day
or two and after that it gives server error( unable to load
MapGuideUnmanagedApi.dll). i have to again deploy the application to make it
working.
what is the probable cause for this dll getting corrupted? how can i resolve
it. i am running into deep trouble because of the malfunctioning of the
application.
Any help will be appreciated.
Kenneth, GEOGRAF A/S wrote:
> Yes, you can add labels runtime, just add a point with an inivisble
> signature, and the label appears.
> To insert the points at runtime, refer to the post on the mailing list,
> that I just made:
> "drawing customized markers on the fly"
> You can edit the data by accessing the datasource.
> If the provider supports updating, you may also edit it.
> If you are considering editing objects in the map, you can use a Fusion
> layout (which uses OpenLayers),
> and then read the WKT from the datasource, and insert it into an
> OpenLayers Vector layer.
> You can then use OpenLayers to edit the vector layer, and optionally
> write data back.
> Regards, Kenneth, GEOGRAF A/S
> Vishaal skrev:
>> Hi Users,
>> i want to know that whether it is possible to add labels to a map on
>> runtime
>> through a text box in MGOS or not??? Also is data editing and addition on
>> runtime is possible in MGOS(same as ArcGIS Server)??? if yes then please
>> do
>> let me know the road map for how to go about these??
>> i am using MGOS 1.2 with Visual Studio2005 on a Windows XP Proffessional
>> SP2, IIS 6
>> thanks in advance.:handshake:
>> Vishal
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Add-Edit-on-map-tp15731997s16610p15735182.html
