[mapguide-users] SV: Translating label icons at main toolbar
Kenneth, GEOGRAF A/S
ks at geograf.dk
Wed Jan 9 06:08:21 EST 2008
I don't think you can, because the translation mechanism does not read
the WebLayout.
In fact, you have to create a copy of each weblayout for each language
you want to support.
The procedure that Måns mentions is another way of editing the Xml in
the WebLayout.
You can create an application that translates any "__#....#__" values
inside a weblayout and saves it with the locale suffixed.
That application can then be executed agains all weblayouts on the server.
You will still have to manually direct the user to the localized version
of the weblayout though.
Regards, Kenneth, GEOGRAF A/S
Jose Manuel C G skrev:
> Can you modify with tags like __#tooltip1#__ with this method? I'd translate
> simply adding this tags to the \localize\en file.
> Måns Beckman wrote:
>> Hi,
>> There is an way to translate the built in commands, but it is kind of
>> tricky. Here is how to do it.
>> Create a new directory in MGS and create a new weblayout in that directory
>> Go to MapGuide Administator and export your new directory as a package
>> (for example swedish.mgp)
>> MGP files is actually ZIP files so change the filetype of your file
>> (swedish.zip)
>> Unzip the contents of your ZIP file
>> Open the file weblayout.WebLayout_CONTENT.xml in Notepad
>> Translate text within <TaskPane> tags (around line 207) name and tooltip
>> can be translated
>> Translate text within <CommandSet> tags (around line 267) label, tooltip
>> and description can be translated
>> Compress your ZIP archive again
>> Change the extension to MGP
>> Import your package through MapGuide Administrator
>> Open MGS and enjoy your localized commands!
>> Best regards
>> Måns
>> -----Ursprungligt meddelande-----
>> Från: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] För lmbap
>> Skickat: den 8 januari 2008 18:34
>> Till: mapguide-users at lists.osgeo.org
>> Ämne: [mapguide-users] Translating label icons at main toolbar
>> Hi all,
>> I'm translating the labels and the menus from english to other languages
>> and
>> I can't find the place where to change the label texts of the built-in
>> commands in the main toolbar, context menu and Task Bar Menu.
>> I'm doing this for MGE2008 and for Open Source.
>> Anyone knows where to change this?
>> Thanks in advance
>> LB
>> View this message in context:
>> http://www.nabble.com/Translating-label-icons-at-main-toolbar-tp14694341s16610p14694341.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080109/31a5d1cb/attachment.html
