[mapguide-users] SV: Translating label icons at main toolbar
Rui Vilanova rui.vilanova at gismedia.pt
Wed Jan 9 06:17:24 EST 2008
You can do that in studio. You just have to duplicate your commands in the weblayout editor page and give them new names, new tooltips, etc.
-----Mensagem original-----
De: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org]Em nome de Kenneth, GEOGRAF A/S
Enviada: quarta-feira, 9 de Janeiro de 2008 11:08
Para: MapGuide Users Mail List
Assunto: Re: [mapguide-users] SV: Translating label icons at main toolbar
I don't think you can, because the translation mechanism does not read the WebLayout.
In fact, you have to create a copy of each weblayout for each language you want to support.
The procedure that Måns mentions is another way of editing the Xml in the WebLayout.
You can create an application that translates any "__#....#__" values inside a weblayout and saves it with the locale suffixed.
That application can then be executed agains all weblayouts on the server.
You will still have to manually direct the user to the localized version of the weblayout though.
Regards, Kenneth, GEOGRAF A/S
Jose Manuel C G skrev:
Can you modify with tags like __#tooltip1#__ with this method? I'd translate
simply adding this tags to the \localize\en file.
Måns Beckman wrote:
There is an way to translate the built in commands, but it is kind of
tricky. Here is how to do it.
Create a new directory in MGS and create a new weblayout in that directory
Go to MapGuide Administator and export your new directory as a package
(for example swedish.mgp)
MGP files is actually ZIP files so change the filetype of your file
(swedish.zip)
Unzip the contents of your ZIP file
Open the file weblayout.WebLayout_CONTENT.xml in Notepad
Translate text within <TaskPane> tags (around line 207) name and tooltip
can be translated
Translate text within <CommandSet> tags (around line 267) label, tooltip
and description can be translated
Compress your ZIP archive again
Change the extension to MGP
Import your package through MapGuide Administrator
Open MGS and enjoy your localized commands!
Best regards
Måns
-----Ursprungligt meddelande-----
Från:  mapguide-users-bounces at lists.osgeo.org
[ mailto:mapguide-users-bounces at lists.osgeo.org] För lmbap
Skickat: den 8 januari 2008 18:34
Till:  mapguide-users at lists.osgeo.org
Ämne: [mapguide-users] Translating label icons at main toolbar
Hi all,
I'm translating the labels and the menus from english to other languages
and
I can't find the place where to change the label texts of the built-in
commands in the main toolbar, context menu and Task Bar Menu.
I'm doing this for MGE2008 and for Open Source.
Anyone knows where to change this?
Thanks in advance
LB
View this message in context:
http://www.nabble.com/Translating-label-icons-at-main-toolbar-tp14694341s16610p14694341.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080109/c81c49d2/attachment.html
