[mapguide-users] Fusion
Berdel, Brian brian.berdel at mcmtrans.com
Wed Jan 9 16:42:28 EST 2008
Not getting much of a response here...So I'll try another question.
Does Fusion work with the .NET configuration of IIS or PHP only?  I have
tried it the samples on multiple machines and cannot get it to work.
Has anyone got it to work with .NET?
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel,
Brian
Sent: Wednesday, January 09, 2008 1:11 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Fusion - Layers do not turn off / on
Some layers actually never load on the samples, and I noticed in firefix
that the status bar says "transferring data from local host"  it just
hangs there...
Any ideas?
Brian
Sent: Wednesday, January 09, 2008 10:10 AM
Is everyone else's working correctly? Just wondering if it is something
I did, or didn't do...If I view a map in a regular viewer the layers
work as they are supposed to...However, if I view a fusion sample or one
of my maps in fusion, they do not respond to the checkboxes...
If I try to turn them on or off, nothing happens...
Brian
Sent: Tuesday, January 08, 2008 4:58 PM
Subject: [mapguide-users] Fusion - Layers do not turn off / on
Just started testing fusion and 2.0...Is anyone else having issues where
their layers will not turn on or off once the map is loaded?
The fusion samples load up correctly, but when I attempt to turn a layer
on or off, the screen just flashes and nothing happens.  The other
normal mapping functionalities are available.
Thanks,
-Brian
Brian
Sent: Tuesday, January 08, 2008 4:42 PM
Subject: [mapguide-users] Symbols 2.0
Sorry if this is a known issue, but I did a quick search and couldn't
find anything...
All of my symbols are appearing on top of each other in the lower left
hand corner of my map in 2.0 beta2.  Anyone else?
Thanks,
Brian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Marc
Pfister
Sent: Tuesday, January 08, 2008 3:31 PM
Subject: RE: [mapguide-users] Mapguide with no map...
I am using the Sheboygan data, and I checked the extents and they are
correct. I'm confused as to why the Sheboygan dataset is throwing
"Unsupported coordinate system code" when I'm trying to output to 4326.
That shouldn't happen.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
GEOGRAF A/S
Sent: Tuesday, January 08, 2008 12:06 PM
Subject: Re: [mapguide-users] Mapguide with no map...
You should try with some data that you know the bounds of (Sheboygan
perhaps?).
I have seen many cases, where the auto-calculated map extents are wrong.
Regards, Kenneth, GEOGRAF A/S
Marc Pfister skrev:
The MG error log doesn't show any errors. The Admin log only shows
successes.
I did manage to generate an error message of sorts. If I use MapAgent to
generate a WMS GetMap request, using the default values it gives for the
Sheboygan dataset ( EPSG 4326 and lat lon bounds in the -87, 43 range),
I get this error:
The coordinate system conversion failed.
Unsupported coordinate system code. The coordinate system conversion
failed.
Exception occurred in method
MgCoordinateSystem.ConvertCoordinateSystemCodeToWkt at line 972 in file
CoordinateSystem/CoordinateSystem.cpp
Proj is the bin folder, and executing ./proj returns the useage:
message.
I'm not sure what's going on, and without any more clues I might just
reinstall and see what happens.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ivan
Milicevic
Sent: Monday, January 07, 2008 11:55 PM
Anything in MG server log???
Pfister
Sent: Tuesday, January 08, 2008 1:50 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mapguide with no map...
I recently installed Mapguide OS on Ubuntu using the wiki pages and
everything seemed to install correctly.
Apache starts and responds fine. I get directory listings and simple
pages or parts of pages.
Mapguide starts fine. Watching the output from starting the startup
shell script, it says it starts up and is using the Proj 4 library.
Map Admin works fine. I can load data packages, etc
However, I can't seem to get any map output.
WebStudio works, though never draws any sample maps (though it only
wants to look at 127.0.0.1, which isn't the right place to look on my
system)
The sample maps, like Sheboygan, don't seem to draw anything. I get a
blank page in the brower when I use the phpviewersample.
MapAgent works for requests like GetCapabilities, but also doesn't draw
any maps with the related tools. I don't know the extents of the sample
data, so maybe that's why I can't get an output from it.
In any case, I never see any error messages show up at the terminal. Is
there a way to make it more verbose?
My next step will be to load a sample shapefile of which I know the
extents so I can give it more complete request for an area to render.
Are there any other troubleshooting steps I should take?
Marc Pfister
Geospatial Data Manager
ENPLAN
mpfister at enplan.com
530/221-0440 x108
530/221-6963 Fax
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080109/d8b9783a/attachment.html
