[mapguide-users] Fusion
Mike Adair madair at dmsolutions.ca
Wed Jan 9 17:17:19 EST 2008
Fusion will only work with PHP at this point.
For the layer toggling issue, I'm not seeing this bug. Are you using a
tiled map? If so, layer toggling won't work because the tiles are served
up with layers on or off as specified by the mapguide server. If you're
not using a tiled map, is there a public instance of your app that we
can look at?
Mike Adair
Berdel, Brian wrote:
> Not getting much of a response here…So I’ll try another question.
> Does Fusion work with the .NET configuration of IIS or PHP only? I
> have tried it the samples on multiple machines and cannot get it to
> work. Has anyone got it to work with .NET?
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Berdel,
> Brian
> *Sent:* Wednesday, January 09, 2008 1:11 PM
> *To:* MapGuide Users Mail List
> *Subject:* RE: [mapguide-users] Fusion - Layers do not turn off / on
> Some layers actually never load on the samples, and I noticed in
> firefix that the status bar says “transferring data from local host”
> it just hangs there…
> Any ideas?
> Brian
> *Sent:* Wednesday, January 09, 2008 10:10 AM
> Is everyone else’s working correctly? Just wondering if it is
> something I did, or didn’t do…If I view a map in a regular viewer the
> layers work as they are supposed to…However, if I view a fusion sample
> or one of my maps in fusion, they do not respond to the checkboxes…
> If I try to turn them on or off, nothing happens…
> Brian
> *Sent:* Tuesday, January 08, 2008 4:58 PM
> *Subject:* [mapguide-users] Fusion - Layers do not turn off / on
> Just started testing fusion and 2.0…Is anyone else having issues where
> their layers will not turn on or off once the map is loaded?
> The fusion samples load up correctly, but when I attempt to turn a
> layer on or off, the screen just flashes and nothing happens. The
> other normal mapping functionalities are available.
> Thanks,
> -Brian
> Brian
> *Sent:* Tuesday, January 08, 2008 4:42 PM
> *Subject:* [mapguide-users] Symbols 2.0
> Sorry if this is a known issue, but I did a quick search and couldn’t
> find anything…
> All of my symbols are appearing on top of each other in the lower left
> hand corner of my map in 2.0 beta2. Anyone else?
> Thanks,
> Brian
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Marc
> Pfister
> *Sent:* Tuesday, January 08, 2008 3:31 PM
> *Subject:* RE: [mapguide-users] Mapguide with no map...
> I am using the Sheboygan data, and I checked the extents and they are
> correct. I’m confused as to why the Sheboygan dataset is throwing
> “Unsupported coordinate system code” when I’m trying to output to
> 4326. That shouldn’t happen.
> *Kenneth, GEOGRAF A/S
> *Sent:* Tuesday, January 08, 2008 12:06 PM
> *Subject:* Re: [mapguide-users] Mapguide with no map...
> You should try with some data that you know the bounds of (Sheboygan
> perhaps?).
> I have seen many cases, where the auto-calculated map extents are wrong.
> Regards, Kenneth, GEOGRAF A/S
> Marc Pfister skrev:
> The MG error log doesn’t show any errors. The Admin log only shows
> successes.
> I did manage to generate an error message of sorts. If I use MapAgent
> to generate a WMS GetMap request, using the default values it gives
> for the Sheboygan dataset ( EPSG 4326 and lat lon bounds in the -87,
> 43 range), I get this error:
> The coordinate system conversion failed.
> Unsupported coordinate system code. The coordinate system conversion
> failed.
> Exception occurred in method
> MgCoordinateSystem.ConvertCoordinateSystemCodeToWkt at line 972 in
> file CoordinateSystem/CoordinateSystem.cpp
> Proj is the bin folder, and executing ./proj returns the useage: message.
> I’m not sure what’s going on, and without any more clues I might just
> reinstall and see what happens.
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Ivan
> Milicevic
> *Sent:* Monday, January 07, 2008 11:55 PM
> Anything in MG server log???
> Pfister
> *Sent:* Tuesday, January 08, 2008 1:50 AM
> *To:* mapguide-users at lists.osgeo.org
> <mailto:mapguide-users at lists.osgeo.org>
> *Subject:* [mapguide-users] Mapguide with no map...
> I recently installed Mapguide OS on Ubuntu using the wiki pages and
> everything seemed to install correctly.
> Apache starts and responds fine. I get directory listings and simple
> pages or parts of pages.
> Mapguide starts fine. Watching the output from starting the startup
> shell script, it says it starts up and is using the Proj 4 library.
> Map Admin works fine. I can load data packages, etc
> However, I can’t seem to get any map output.
> WebStudio works, though never draws any sample maps (though it only
> wants to look at 127.0.0.1, which isn’t the right place to look on my
> system)
> The sample maps, like Sheboygan, don’t seem to draw anything. I get a
> blank page in the brower when I use the phpviewersample.
> MapAgent works for requests like GetCapabilities, but also doesn’t
> draw any maps with the related tools. I don’t know the extents of the
> sample data, so maybe that’s why I can’t get an output from it.
> In any case, I never see any error messages show up at the terminal.
> Is there a way to make it more verbose?
> My next step will be to load a sample shapefile of which I know the
> extents so I can give it more complete request for an area to render.
> Are there any other troubleshooting steps I should take?
> n
> Marc Pfister
> Geospatial Data Manager
> ENPLAN
> mpfister at enplan.com <mailto:mpfister at enplan.com>
> 530/221-0440 x108
> 530/221-6963 Fax
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
