[mapguide-users] Issues selecting a feature with custom coding
nclayton
nclayton at gmail.com
Thu Jan 10 09:12:31 EST 2008
Here are the results of both the mgos base64 value and the php base64_encode
value:
Actual FeatId: 33181
MGOS Value: nYEAAA==
base64_encode Value: MzMxODE=
I found code for writing a base64 function in javascript, and it gives the
same result as the php function.
Kenneth, GEOGRAF A/S wrote:
> If you select the feature, you can read the WKT or BoundingBox for the
> object.
> With this info, you can calculate the Center X,Y + Scale, and manually
> zoom to it.
> I have not worked enough with the selection to understand it completely.
> However, I think you are mistaken about the Base64 functions not being
> compatible.
> What appears to be different about the two encodings?
> If they truly are different, it is very easy to write your own base64
> encoding/decoding functions.
> Regards, Kenneth, GEOGRAF A/S
> nclayton skrev:
>> Hi everyone,
>> Here is my situation:
>> I am hacking up the mapviewerphp files to fit the needs of the company I
>> work for. One piece of functionality that is requried is that after a
>> user
>> queries our database for owner information, it is displayed in a new
>> frame.
>> Along with this information, there is a 'Zoom to Parcel' link. When the
>> user
>> clicks this, it should zoom to that parcel and select it without
>> affecting
>> the owner data list.
>> My issue right now is in the selection of the parcel. I'm folling the
>> code
>> given in the dev guide, but my $selection->ToXml() always comes out as:
>> <?xml version="1.0" encoding="UTF-8"?><FeatureSet
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"></FeatureSet>
>> I am creating and passing in a query filter of "PARCEL_ID_ = '12345'"
>> (with
>> the appropriate parcel number supplied of course). I know that this
>> PARCEL_ID_ value exists.
>> I have tried manually creating the featureset query, since I can get the
>> feature id of the selected parcel. The problem with that is that mgos
>> uses a
>> base64 encoding that doesn't match php's base64_encode() output, so
>> that's a
>> no-go as well.
>> Any help and suggestions are appreciated
>> Nick
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Issues-selecting-a-feature-with-custom-coding-tp14694817s16610p14733863.html
