[mapguide-users] Issues selecting a feature with custom coding
nclayton nclayton at gmail.com
Thu Jan 10 11:29:11 EST 2008
Thank you for the reply and the link. I'd actually read that post, but it
gave me a bit of a headache trying to reverse the process...I'm rather new
to this mode of thinking (i avoided it as long as i could).
As far as the parcel number value is concerned, it needs to be a string
because they are different for each county that we deal with and are
typically 14-22 alphanumeric characters in length, such as '1-023B-001.000'
Nick
JasonBirch wrote:
> More details on this here:
> http://tinyurl.com/2rrq3e
> I'm definitely a bit rusty on this stuff, but in your initial problem
> are you sure you want to be using a string value for the parcel id?
> Jason
> -----Original Message-----
> From: nclayton
> Subject: Re: [mapguide-users] Issues selecting a feature with custom
> coding
> Here are the results of both the mgos base64 value and the php
> base64_encode
> value:
> Actual FeatId: 33181
> MGOS Value: nYEAAA==
> base64_encode Value: MzMxODE=
> I found code for writing a base64 function in javascript, and it gives
> the same result as the php function.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Issues-selecting-a-feature-with-custom-coding-tp14694817s16610p14737912.html
