[mapguide-users] Issues selecting a feature with custom coding
nclayton nclayton at gmail.com
Thu Jan 10 12:52:33 EST 2008
I have created this function in php which gives me the correct value for
33181 ("nYEAAA==") but I would like for another pair of eyes (or 20) to see
if this is solid and if it can be simplified.
function MgBase64_encode($value){
	$key="ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=";
	$dhv = dechex($value);
	$grp = (strlen($dhv) / 2);
	$arr = array();
	for($i=0;$i<$grp;$i++){
		$arr[$i] = substr($dhv,($i * 2),2);
	$arr = array_reverse($arr);
	$bvl = decbin(hexdec(join("",$arr)));
	$chk = (strlen($bvl) % 6);
	if($chk > 0){ $bvl = str_pad($bvl,(strlen($bvl) + (6 - $chk)),'0'); }
	$grp = (strlen($bvl) / 6);
	$arr = array();
		$arr[$i] = substr($key,bindec(substr($bvl,($i * 6),6)),1);
	return str_pad(join("",$arr),6,'A') . "==";
Nick
nclayton wrote:
> Thank you for the reply and the link. I'd actually read that post, but it
> gave me a bit of a headache trying to reverse the process...I'm rather new
> to this mode of thinking (i avoided it as long as i could).
> As far as the parcel number value is concerned, it needs to be a string
> because they are different for each county that we deal with and are
> typically 14-22 alphanumeric characters in length, such as
> '1-023B-001.000'
> Nick
> JasonBirch wrote:
>> More details on this here:
>> http://tinyurl.com/2rrq3e
>> I'm definitely a bit rusty on this stuff, but in your initial problem
>> are you sure you want to be using a string value for the parcel id?
>> Jason
>> -----Original Message-----
>> From: nclayton
>> Subject: Re: [mapguide-users] Issues selecting a feature with custom
>> coding
>> Here are the results of both the mgos base64 value and the php
>> base64_encode
>> value:
>> Actual FeatId: 33181
>> MGOS Value: nYEAAA==
>> base64_encode Value: MzMxODE=
>> I found code for writing a base64 function in javascript, and it gives
>> the same result as the php function.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Issues-selecting-a-feature-with-custom-coding-tp14694817s16610p14739683.html
